EIMTS Question
Old Jun 5, 2011 | 05:18 PM
Mrkolivers's Avatar
Mrkolivers
Default EIMTS Question
Bike is a 2010 FLHTK Trying to determine if EITMS is on. The owners manual says to turn the ignition to on, turn the off/run switch to run, and then roll the throttle forward for 3 seconds. What does roll the throttle forward mean? Do I give it some gas (motor is off)? The directions seem simple but I can't seem to turn the cruise control icon green or red. I suspect I am not doing something right with the throttle.
Does the cruise control switch need to be in the on position?
I am just trying to determine if this feature is on where I can leave it on.
Thanks for any help.
Old Jun 5, 2011 | 05:25 PM
DPete's Avatar
DPete
You roll the throttle the opposite way you would give it gas, forward toward the front wheel from idle position. It doesn't move far, just hold it there and you will see the light change and you are done, no the cruise switch does not need to be on
Old Jun 5, 2011 | 05:28 PM
johnbasf's Avatar
johnbasf
Switches on and roll the throttle away from you until it stops. Hold for 3 and look at the cruise light.
meintel
Jun 12, 2023 09:55 AM
Mrfixitman
Aug 22, 2018 07:48 AM
Bart van der Meulen
2014-2024 Touring Models
19
Oct 22, 2015 06:54 AM
martinfd
Electrical/Lighting/Alarm
Jun 14, 2015 12:33 AM
stimul8ing guy
Mar 25, 2008 08:48 AM
