will they fit?
asking for a friend....
will the leather bags from an earlier model (pre 2009) road king classic fit on a 2011 road king? i checked the part number in my parts manual, and they do have a -09 identifier, but that could be for any number of reasons.
i know the hard bags will fit from 98 on, i don't know why these would be any different, but stranger things have happened...
I have a set of RoadKing custom bags that I refinished they were off of a 06 RK and they will not fit the 2010 RK that I have - the mounts on the "new frame" seem to be further apart than the 06 mounting holes
skratch, the saddlebag brackets probably just need to be loosened and adjusted for using the other bags.
I saw where you checked the part numbers and the newer versions have -09 suffix. So it may be a no go.
Carl
Carl
but it's just the newer versions of the leather bags. the hard bags are still using the same number. so is there just a cosmetic change to the leather bags, or is there some reason they won't fit..... wish i knew someone around here who had a newer rkc......
