reason why primary has no magnetic drain plug
Old Jun 15, 2011 | 09:31 PM
speakerfritz's Avatar
speakerfritz
Default reason why primary has no magnetic drain plug
I noticed that my 07 ultra only has 2 out 3 drain plugs that are magnetic. I wondered why the primary did not have one and was thinking of adding one. but after thinking about it, it wouldn't do any good.....the magnets in the stator assembly probally pickup all the metal fragments. ANyone ever notice metal particles on the stator magnets when doing stuff like compensator work?
Old Jun 15, 2011 | 10:01 PM
Potato_Potato's Avatar
Potato_Potato
I believe they are magnetic plugs - mine is and has been on the 3 HDs I have owned. The late model years are the same exact plug as the crank and tranny. The older ones were smaller but had magnets too. Are you sure yours was not replaced with an aftermarket one that wasn't?
Old Jun 15, 2011 | 10:15 PM
SICKBAGGER's Avatar
SICKBAGGER
My 08 has one all 3 holes are same plug, better get you one!
Old Jun 15, 2011 | 10:28 PM
bwana1's Avatar
bwana1
They are all magnetic.
bwana1's Avatar
bwana1
and the primary plug will always have a beard of some sort.
Old Jun 15, 2011 | 11:16 PM
speakerfritz
OK, sounds like I need to go out and get one. Out of three plugs, only two have the magnet core.
Old Jun 15, 2011 | 11:50 PM
lh4x4's Avatar
lh4x4
I just did the three holes yesterday and all three had the small plug with magnet.
Old Jun 16, 2011 | 06:41 AM
ezriderpgh's Avatar
ezriderpgh
Those little magnets do come out of the plug once in a while. So now the question is, did someone replace your stock plug or did the stock plug lose the magnet and if it did where is it? hmmmmm
Old Jun 16, 2011 | 07:32 AM
iclick's Avatar
iclick
My '07 SG has three magnetic drain plugs, as did my old '96 Evo RK.
Old Jun 16, 2011 | 08:35 AM
sargek's Avatar
sargek
My '07 Ultra has all three magnetic - primary always has more gunk than the others from I'm assuming the clutch and possibly the chain tensioner since those are the only two items that are "consumable" and slowly wear down, leaving material.
traildog
2014-2024 Touring Models
36
Dec 22, 2017 07:49 PM
Robtarra39
Apr 27, 2011 08:01 PM
NewfieRocker
18
Jan 1, 2010 01:05 PM
blainem
19
May 30, 2007 04:29 PM
jaymar
Aug 6, 2006 11:10 PM
