riser bushings
Old Jun 16, 2011 | 02:35 PM
johnnyfd's Avatar
johnnyfd
5th Gear
Default riser bushings
I'm not the sharpest tool in the shed, but it seems to me that FSM doesn't have any instruction on replacing these. Besides the PITA of having to remove the faring does anyone know of anything important I should keep in mind? Or is it pretty straightforward? And what do I torque that **** at?
2002 ultra
Old Jun 16, 2011 | 02:38 PM
Redbeard719's Avatar
Redbeard719
No experience replacing them yet, but I will this winter.
From the 2010 Service Manual:
Handlebar lower clamp bolts (risers) 30-40 ft-lbs.
Old Jun 16, 2011 | 03:25 PM
johnnyfd's Avatar
johnnyfd
5th Gear
that sounds about right........I just found it strange it wouldn't be in the FSM. I'm thinking I missed it........but I looked a few times.....what chapter that in on the 2010?
Old Jun 16, 2011 | 03:37 PM
Redbeard719
It's in Chapter 2 in the touring models service manual.
Old Jun 16, 2011 | 04:20 PM
johnnyfd's Avatar
johnnyfd
5th Gear
k...thanks fish.......it's not in my manual.....that seems f**ked. I'll manage it; I just like to have the book with me. kind of like motorcycle maintenance for dummies.
Old Jun 16, 2011 | 04:44 PM
fabrik8r's Avatar
fabrik8r
You didn't specify but I hope you are replacing them with urethane bushings, if so retorque them 3-4 times allowing a few miutes rest in between so the material has a chance to settle.
Old Jun 16, 2011 | 05:00 PM
TexasSG's Avatar
TexasSG
I replaced mine with urethane ones when I put the 12" bars on, no instructions necessary, it's just a couple bolts, spacers, washers and ground straps. Tighten them till they're tight.
Torque spec? We don't need no stinkin' torque spec!
"tight's tight..........too tight's broke"
Old Jun 17, 2011 | 11:06 AM
dc1057's Avatar
dc1057
I was curious on the urethane bushings. What's the benefit? I thought they might transfer more vibration than the stock mounts?
Old Jun 17, 2011 | 11:56 AM
Harleypingman's Avatar
Harleypingman
If you have a buddy lift up and hold the handlebars for you, the old bushings can be removed and new bushings installed w/o removing the inner fairing or radio. I did mine a year or so ago this way.
Carl
emdx3
Apr 13, 2019 06:12 PM
NativeTexan
Mar 24, 2016 01:23 PM
d24112
Touring Parts
Feb 2, 2016 08:15 AM
hapbob
Touring Parts
Jun 9, 2012 06:56 AM
Spinnr
May 17, 2012 08:56 PM
