brakes lock up
Old Jun 19, 2011 | 06:18 AM
1st 96 ultra's Avatar
1st 96 ultra
Default brakes lock up
have not had my 07 Ultra very long but put a D401 tire on the rear that I took off the wifes bike when I did her custom work , any way have noticed that the rear tire will lock up on a hard stop pretty easy , no I do not use the front brake , so I am woundering is it the tire , my braking technique or do I just need to quit my diet for more down pressure
Old Jun 19, 2011 | 06:27 AM
TORQUEY's Avatar
TORQUEY
Be gradual on the down pressure, even when braking hard. Don't employ the "light switch" technique. Check to see that the D401 is properly inflated and that there is no obvious defect such as cupping or uneven wear.
That having been said, I find few things more important than the front brake. When I have to replace brakes, GUARANTEED that my fronts will be worn way before the rear, thought I try as often as I can to use them in tandem. Not only will it stop the bike MUCH more quickly, but it will very much reduce the tendency of the rear to lock up, since the fronts arguably do 60-70% of the work.
Old Jun 19, 2011 | 07:15 AM
1st 96 ultra
well do not like the front brake method , have heard to many stories about people hitting a patch of sand or gravel and going down , may need to practice though cause to not like the idea of not being able to stop quick either
Old Jun 19, 2011 | 07:29 AM
Paniolo's Avatar
Paniolo
When you use the front brake, just make sure that he bike is upright and the bars are straight. Try and remember the saying "Brake Straight". A lot of front brake mishaps occur when the bike is turning and leaned over. On the freeway going 80mph with the bike upright and going straight the front brake is your friend, it's the one you want to use. Snaking your way through city traffic or manuevering in close quarters with the bars turned the front brake is not ideal. Yes, it is possible to use front brake in a curve like track racers do but that takes a lot of practice on a track in a track environment under controlled conditions.
Having said all that go out and practice threshold combination braking. Starting at 15mph, use both brakes with a smooth progressive application, meaning don't let off. Try and bring the brakes to the point of imminent lock up with out locking them up. This will allow your muscles and body to learn and feel what the bike is doing. If you hear a slight single "chirp" as the bike stops then you are at the max. If you skid any distance you are over braking.
Hope this helps
Old Jun 19, 2011 | 07:43 AM
cochon's Avatar
cochon
You really should think about taking a Motorcycle Safety Foundation Experienced Rider course. The instructors there will help you to become a safer rider and perhaps help you to rethink your aversion to using the front brake (60%-70% of your stopping power). I have taken the course several times and I have learned something every time that I took it.
Old Jun 25, 2011 | 02:21 PM
1st 96 ultra
found out my bike has a ABS symbol on the gauge , light dose not light up at all and do not know if it ever did so I was woundering if my bike might have ABS that quit working and causeing my brake problem , ask my local dealer and the service manger said it came out in 07 and his mechanic said 08
Old Jun 25, 2011 | 09:57 PM
AlanStansbery's Avatar
AlanStansbery
Here's another vote for you to learn to use your front brake. A lot of good advice in the earlier posts. Using the front, you'll cut your average stopping distance at least in half. Think about that. Take that advance MSF course and let us know how it goes...
Alan
Old Jun 25, 2011 | 10:02 PM
av ultra's Avatar
av ultra
Also the tire might be harder then the one you took off, resulting in loss of tracton. You really need to get confortable with the front brake tho, it will save your life- and back tire wear.
Old Jun 25, 2011 | 11:33 PM
stafford's Avatar
stafford
There's a reason you have two rotors and calipers on the front wheel and only one on the rear. Think about it. Like you i was pretty leery of that front brake, but if you wanna stop, you gotta use it.
Old Jun 26, 2011 | 12:54 AM
jazzy jack's Avatar
jazzy jack
Please, learn to use and be comfortable with your front brake in all situations, it will make you a better and safer rider. The proper and controlled use of both brakes is a life saver and will help make sure you come home to your family in one piece.
