cruise control wiring
hey my name is joe and new to this forum! looking for a quick answer if possible. i am pretty mechanically inclined, but trying to install cruise control onto my 2011 road glide. i have the controls all wired up and connected as the dicrections say to do so. i also have the cruise control switch set into the switch cannal. the only step i am having trouble with is connecting that switch into the wiring harness due to the fact i dont know what cavity to put them in. if someone has a diagram that would be greatly appriciated thank you! Just so you know what step im on the harley directions say : Refer to the service manual, and follow the instructions to insert the switch wire terminals into the 12-way socket houseing [105B] as follows :
orange/voilet wire to cavity 4.
red/green wire to cavity 5.
black/green wire into cavity 12.
Just need to know what cavitys these are on the socket thank you!!!!
Sounds like you are having difficulty identifying the numbers of the cavaties. There are very small embossed/molded numbers on the wire insertion side of the connector identifying the cavaties. Lots of light and good eye sight/magnifying glass may help to read the numbers.
It's been a while since I did this install, but, typically, the wire colors on one connector are the same as the wire colors of the mating connector.
Hope you figure it out.
Carl
Carl
Carl
Carl
What he said^^^^^^^^^^^^^^^^^
Not an easy job but not tough. I have wired a couple up and talked a couple other people through it. Make sure you run to the dealer and have the cruise turned on in the ECM
[QUOTE=18BKLR;8484371]What he said^^^^^^^^^^^^^^^^^
Not an easy job but not tough. I have wired a couple up and talked a couple other people through it. Make sure you run to the dealer and have the cruise turned on in the ecm
I just installed cruise on my 2011 SG and it isn't functioning. You're saying I need to have the dealer turn it on in the ecm? The light on the switch comes on but not on the gauge. Also, 1 of the wires is suppose to be connected to the speaker switch ground if I have it. I'm assuming that is if you have rear speakers which I don't. I left it taped up. Any other suggestions?
Thanks, Dave
Thanks, Dave
simplewell
02-10-2013 09:57 AM
