2003 fuel line ?
Old Jun 23, 2011 | 10:04 PM
al baehr's Avatar
al baehr
Default 2003 fuel line ?
Hello, I have a gas leak on my o3 ultra, I thought it was the quick connect so I replaced that tonight. Got it all put back together and still leaking, so I guess I need to change the fuel line. Can anyone tell me if this a huge job?, I am looking in my manual but cant find on how it connects to the injector area. Thanks Al
Old Jun 23, 2011 | 11:43 PM
stuart1270's Avatar
stuart1270
The fuel line was updated. Just changed it on my buddy's 03 ultra. cost about 48.00 but is a much better piece then the original. the tank end was easy the throttle body end is tricky. I ended up taking off the tube that the fuel went connected to. The injector end is similar to the ford ac hose connections . Not a big job.
Old Jun 24, 2011 | 12:51 AM
al baehr's Avatar
al baehr
Thanks for the info, was the 1 you replaced leaking by the tank ?. Looks like I changed the quick disconect for nothing but at least I know its good for some time now..
Did you have to pull the tank to get it replaced ?
Old Jun 24, 2011 | 04:52 PM
stuart1270's Avatar
stuart1270
The hose came off by the tank and no did not have to pull the tank.
Old Jul 10, 2011 | 07:46 PM
Flyboycyyz's Avatar
Flyboycyyz
Stage I
2003 FLHRI
I just had the tank off to install J&M CB and HD air horn. Re-installed tank,and now have fuel leak at the hose or connection that goes to injection system. I know I need to replace the line and have found the part I will need on this forum.
My question: do I need to drain tank again to replace this line?
Thanks in advance for help and advice.
Old Jul 10, 2011 | 08:26 PM
1flhtk4me's Avatar
1flhtk4me
Originally Posted by Flyboycyyz
2003 FLHRI
If you are just replacing the line from the tank to the FI module ,no.
Connect the line to the FI first,then to the tank.
Anytime working with possible gas spills,do it away from water heaters,etc-.
cptseawolf
Feb 26, 2017 03:49 PM
High Roller
Mar 14, 2015 07:07 PM
Gman in NC
Sep 5, 2011 01:02 PM
CMAchris
Jan 5, 2009 02:02 PM
anubisss
Oct 14, 2006 12:38 AM
