Left Passenger Peg
Old Nov 5, 2006 | 10:40 AM
Kern's Avatar
Kern
Default Left Passenger Peg
I went out early this morning with the intent of putting on the new passenger floorboards I put together last night. Right side went fine, but the left is giving me some trouble. The only way I can see to get it off is taking off the muffler and pipe that runs up the side. The bolt is tucked up next to the pipe. When I put the allen wrench on its either sitting on the primary cover, or on the pipe. No leverage and not enough room to even break it loose.
If I had a 5/16 allen socket that connected to a 1/4 or 3/8 ratchet, I think it would work fine. Do they make "allen sockets"?
Anyone have a trick for getting the bolt up in there out without removing the Bassani exhaust?
Thanks for any input.
-Kern
Old Nov 5, 2006 | 10:47 AM
lp's Avatar
lp
Default RE: Left Passenger Peg
Yes they do and thats what I had to do. Just go on down to advance auto or autozone and buy one for a few bucks. Don't try using a normal allen wrench, you just end up ruining some chrome..
lp
ORIGINAL: Kern
Old Nov 5, 2006 | 11:00 AM
BOARGAURD's Avatar
BOARGAURD
Yes they do make the tool, just be careful, them bolts are friggen tight, I had to replace mine cause it just barely came off before it stripped out.
Old Nov 5, 2006 | 11:17 AM
1flhtk4me's Avatar
1flhtk4me
The bolts have loctite on the threads and are tight.
Old Nov 5, 2006 | 11:18 AM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
They do make ball allen for your socket wrench too.
Old Nov 5, 2006 | 11:28 AM
xxxflhrci's Avatar
xxxflhrci
Run on down to Sears and get you a set of hex sockets. Then, use one with a long extension to take the bolt out.
[IMG]local://upfiles/17633/A8F8D2F5DBFF47D6ACCD568B539A7B72.jpg[/IMG]
Old Nov 5, 2006 | 12:25 PM
electaRICK's Avatar
electaRICK
Left Passenger Peg,,,,,,,,,,,,,,once,,,,,,,,,,,,
,,,,,,,now she wont talk to me
Old Nov 5, 2006 | 12:38 PM
rideon's Avatar
rideon
If you have a buddy with a air gun you will crack that bolt alot easier, saves stripping it out if its a problem.
Old Nov 5, 2006 | 12:57 PM
PrplRdKing's Avatar
PrplRdKing
ORIGINAL: electaRICK
Booooooooooooo! Hisssssssssssssssss!
Old Nov 5, 2006 | 03:04 PM
voodoodrug's Avatar
voodoodrug
dont forget to put them up
