o-ring chains??
Old Jul 4, 2011 | 08:19 AM
bubba4u's Avatar
bubba4u
Default o-ring chains??
about how long does a o-ring chain supose to last? i got 16000 miles on mine and it's starting to make poping noises
Old Jul 4, 2011 | 08:23 AM
dc1450's Avatar
dc1450
It depends, how old is it, do you ride in the rain? 16k isn't bad. The real question though is what happened to the enclosed chaincase on your bike, those chains lasted forever.
Old Jul 4, 2011 | 09:01 AM
bubba4u's Avatar
bubba4u
the bearing frozed up on me and rung the axle into, messed the rim up so i changed it over, a lot easier and cheaper, had a few problems with that rear setup and got reid of that headache
Old Jul 4, 2011 | 09:18 AM
Sharknose's Avatar
Sharknose
How long they last depends on how well you keep them lubed.
Old Jul 4, 2011 | 09:24 AM
dc1450's Avatar
dc1450
They did make changing the rear tire a pain but, I ran my '02 Tour Glide 27,000 miles with no problems, rarely even had to adjust the chain.
On your bike, you may need a chain but, I would try to lubricate it first. The purpose of the O rings is to keep the factory lube in. It also keeps your lube out so the chain may have to be replaced anyway.
Old Jul 4, 2011 | 09:41 AM
Fathead2003's Avatar
Fathead2003
What exactly is a O Ring Chain?
Old Jul 4, 2011 | 10:17 AM
grbrown's Avatar
grbrown
Wink
Recent chains have an O ring rubber seal at each end of each roller and are lubed on the inside. Older chains had to be lubed from the outside, in the hope some of it gets to the inside of the rollers!
On the other hand, if you are having a bit of fun, it's an endless rubber neck-chain.....
Old Jul 4, 2011 | 10:31 AM
Sharknose's Avatar
Sharknose
Google is your friend: http://www.quality-cycle.com/truth_a...cle_chains.htm
Old Jul 4, 2011 | 10:58 AM
Beemervet's Avatar
Beemervet
Assuming your sprockets are OK, a popping chain isn't good. Put a new one on, and be thankful you do not have a belt.
Virginia Squire
13
Jan 9, 2022 11:23 AM
Hx3
Apr 14, 2009 11:55 AM
JosephGarcia
Jan 31, 2008 10:41 AM
Jughugger
May 22, 2007 01:10 AM
V2 Bagger
Apr 9, 2006 04:08 PM
