Replacing the rear brake light switch
Old Jul 12, 2011 | 10:04 AM
  #31
shortride's Avatar
shortride
I talked to an indy about mounting and bleeding the rear brake on my '09 Ultra Classic with ABS. He said unfortunately the Digital Technican II is a must have when bleeding brakes on an ABS sytem. He also said that trying to bleed an ABS sytem will not get all of the air out of the ABS module and can cause the ABS brake to fail when you need it the most. It can cause the rear brake to lock up or not work at all.
So I guess it's to the dealer and $85 after all.
Old Jul 12, 2011 | 02:59 PM
  #32
Potato_Potato's Avatar
Potato_Potato
I have bleed mine with ABS many times without the DT - the following explains when you have to have the dealer use the DT.
This is from the '08 Touring SM:
If motorcycle is ABS equipped,and either the ABS module or more than one brake line was removed, confirm that brake system is properly connected. To accomplish this, connect motorcycle to DIGITAL TECHNICIAN II (Part No. HD-48650) and perform "ABS Service" procedure in the "Toolbox" menu.
Old Jul 12, 2011 | 05:35 PM
  #33
shortride's Avatar
shortride
Thanks! I didn't know Harley ABS system was around in 2008. Shows how much I don't know.
My 2009 SM states "ABS equipped motorcycles require the use of Digital Technician II HD-(48650) to confirm that the brake lines are properly connected and that air is adequately bled from ABS unit."
"WARNING! Any time the ABS module, either master cylinder, or any line between a master cylinder and the ABS module is disconnected or replaced, Digital Technician II must be used during the brake bleeding procedure. Failure to do so could result in air in the hydraulic brake system, reducing brake efficiency, which could result in death or serious injury."
Old Jul 16, 2011 | 10:29 AM
  #34
shortride's Avatar
shortride
Had the dealer install the rear brake light switch this morning. As most of you said, the Digital Technician did not have to be used.
A $66 lesson learned.
Old Jul 21, 2011 | 10:11 PM
  #35
ROLLNTIGER's Avatar
ROLLNTIGER
Mine went out this week also. 2007 Heritage. Did a search and on other forums it's a pretty wide spread problem.
Old Jul 21, 2011 | 11:55 PM
  #36
Potato_Potato
You can cross reference that switch at an auto supply store.
Old Jul 22, 2011 | 07:55 PM
  #37
05king's Avatar
05king
Add me to the list. Today I installed the rear fender tip run/brake light on my '09 Ultra and when testing it out, I noticed the foot brake pedal did not engage the brake lights. The front lever works fine. After reading several entries here, I guess my switch is now toast. Warranty ran out this week too. Harley life is so much fun!!
Old Jul 22, 2011 | 11:06 PM
  #38
ROLLNTIGER's Avatar
ROLLNTIGER
I tried and went to 5 different auto parts stores and if your willing to wait a day or two you can save 10.00. Not really worth it. Went to the dealer and it was 21.00 with tax.
Old Jul 23, 2011 | 01:23 PM
  #39
Cotton Hill's Avatar
Cotton Hill
My name is cotton hill and I'm a member of the "Harley rear brake light switch Anonymous".
My switch went out on the way to work Wed. I hit the cruse and nothing. Checked it out and found switch in the ON position. Got a new one at the dealer $26.
2008 RG w/46,000 miles.
Old Jul 23, 2011 | 06:03 PM
  #40
ftanner's Avatar
ftanner
Count me and my '09 Road King Classic in this list too. I will replace it at some point in time.
