Brakes something ain't right....
Old Jul 7, 2011 | 01:51 AM
03dragonRK's Avatar
03dragonRK
It's a pain, but you should clear the pistons in the caliber. Howard has a great write up on this under DIY at his web site motorcycle metal. Then replace the brake fluid (this should be done eyery two years) and see if that fixes your problem.
The groves in the rotor may have been caused by your old pads although your machanic should have told you about it. Are the groves deep, or can you just feel them? If deep I would replace the rotor and sand the pads down to remove any groves that the rotor caused. 50 grit paper on a flat surface works well for that (wear a dust mask).
Old Jul 7, 2011 | 02:05 AM
Guntoter's Avatar
Guntoter
I am going to throw out a different theory here: you are just plain using too much rear brake in a fast stop. Secret to application of the rear brake on an Electra Glide type bike is to just rest your toes on the rear brake lever pad and apply the front brake, when the bike dips and your body shifts forward your foot will automatically push the rear brake. You need very little of the rear brake to stop with. Since you only had the problem when reacting to stopped traffic in front of you I think it was too much rear being applied.
Old Jul 7, 2011 | 02:24 AM
03dragonRK's Avatar
03dragonRK
Would agree if he was locking them up and then releasing, but he is describing the brakes as locking and releasing on their own. Of course if he is pumping the rear brake that could do it as I found it very easy to lock up the rear on my 03 RK.
Old Jul 7, 2011 | 10:29 AM
MyFirstHD's Avatar
MyFirstHD
If you haven't taken the rear caliper appart that is a good suggestion. My bike was eating pads and not stopping well until I tore the caliper appart, cleaned it, added fresh fluid and bled the brakes.
Old Jul 7, 2011 | 11:13 AM
jjpish's Avatar
jjpish
Thanks I am running over to the HD shop today and getting a print out of what they did in March. I appreciate the suggestions and need to figure this out.
I would like to think that I am just breaking too hard in traffic but I have 56,000 miles on my bike and find it hard to believe that in the last two weeks I started breaking too hard...
Old Jul 7, 2011 | 12:30 PM
Notgrownup's Avatar
Notgrownup
I would think it's mechanical somehow...bad pins, dirty caliper, air in system etc....
Old Jul 7, 2011 | 04:17 PM
RHillbilly's Avatar
RHillbilly
sounds like fluid is getting hot with the traffic
Old Jul 7, 2011 | 05:12 PM
dstrat1's Avatar
dstrat1
I am assiming that by chirp you mean the back wheel was starting to slide...My guess would be that in a stress full stop situation you were probably on the front brake hard enough to lighten the back, which without abs would allow the back to lock up sooner.....
Alamomann
Oct 20, 2016 09:58 AM
Cazador
Jun 26, 2016 10:31 AM
doc_cj
Dec 28, 2007 03:32 PM
cadillac
May 1, 2007 06:08 PM
