what to look for in primary case
Sometimes the teeth on the tensioner ramps will wear and cause the rig to slip (mine would do that until I took a fine file and sharpened the teeth)...look there as well.
Good luck.
So, it seems to me, you will need to take the primary cover off, take a look, and possibly replace the primary tensioner, and check the torque on the nuts in there while it is open.
The tick is more than likely the chain smacking the cover.
If you are using a multi-viscosity oil in there, it may be that the oil is too thin, but as it heats up, the oil is thicker, and thus is sufficient to pump the adjuster up. So, if you are using 10W30 in their, and switch to 20W50 and it stops, then it wanted thicker oil.....probably shouldn't matter, so then again, it could mean the adjsuter needs replacement.
Just my .02
~Joe
