Loud horn
Old Jul 11, 2011 | 08:41 PM
AbnMP13's Avatar
AbnMP13
Got a link?
Originally Posted by maineultraclassic
I just picked up a pair of Fiamm Freeway Blasters, mounted one behind each saddlebag......loud as hell. They are rated at like 132db, so with both it's 135db dual tone.
My Stebel air horn just died, so I'm all done with them.............normal horns are much more dependable. Never had good luck with air horns ever, compressors always die or the diaphragms break in the horns.
Steve
Old Jul 11, 2011 | 09:05 PM
Potato_Potato's Avatar
Potato_Potato
When I had my Lowrider I replaced the horn with a Stebel which was advertised at the time as the loudest magnetic horn made. I got the automobile version which included 2 horns (high & low) and was only $20, if I remember correctly. There is no reason to buy a Harley Stebel - its the same thing except you only get one.
It fit fine after bending the tabs that plugs go on.
Old Jul 13, 2011 | 02:49 PM
Bull_Duck's Avatar
Bull_Duck
I just bought the Stebel high/low combo. High tone going on wife's '98 Dyna. Low tone on my 2000 Deuce.
Old Jul 13, 2011 | 03:53 PM
Neckball's Avatar
Neckball
I've got some type of air horn, the dual chrome trumpet style, Howard's, Rivco, I forgot. Had them installed at a rally in 2006. A few years back one of them stopped working. So I called to buy the single replacement trumpet. The lady on the phone suggested I try something first.
She said my air horns have a reed in them, just like in a clarinet or a saxophone. She told me to give it a shot of WD-40. That fixed my horn. I was told to do that maybe once a year to keep the reeds in good working order. So far, so good.
Old Jul 13, 2011 | 07:54 PM
Egras2k's Avatar
Egras2k
I broke apart a Wolo, put the horn in place of the stock and remote mounted the compressor. Was loud and ran well. The new ones don't look as if they come apart the same. I might try that direct replacement up top there for this bike.
Old Jul 13, 2011 | 08:16 PM
HD-Frog's Avatar
HD-Frog
5th Gear
little larger than stock, but still small... mini-beast 5
http://www.customdynamics.com/mini_beast_air_horns.htm
definately the loudest at that size, check it out:
http://www.youtube.com/watch?v=SvFdv...eature=related
Old Jul 13, 2011 | 09:54 PM
mrbones76's Avatar
mrbones76
I bought a air horn from www.metalartsinc.com It is a little bigger than stock horn and it is from their magnum line. It is a plug and play horn with flame cover. They powder coated it black at no charge. It is rated at 139 decibels. I have had it 2 1/2 years with no problems. It was pricey but I liked it
Old Jul 13, 2011 | 11:18 PM
papifun's Avatar
papifun
i have mini-beast... 2 years and still works ... nice and loud too..does the job when required...
Old Jul 14, 2011 | 07:14 AM
mudbeast2's Avatar
mudbeast2
Thanks for the advise guys, I put those Kuyakn airhornd on my dads ultra. they worked good but if the horn touched the saddle bag at all it would not work. So there was alot of fine tuning. My brother thas that little chrome one with the air pump on his and that sucker is loud. I may try the one from Amazon see how that goes. Thanks again.
Old Jul 14, 2011 | 09:16 AM
Biker Chad's Avatar
Biker Chad
I recommend RIVCO's part number ELCHRN ($79.95) and the wiring kit EH275 ($39.95) this set is 118db one horn mounts under the stock cowbell (or in your case the skull cover you have) and the other mounts on the lower left engine gaurd bolt (or any where else you have an open spot). I have had them mounted on my 2006 Dyna Street Bob since 2005 with no issues. They sound like a super loud car horn, very effective and they look great. The wiring kit makes the installation almost totally plug and play. My horns have saved my a$$ many times!
Last edited by Biker Chad; Jul 14, 2011 at 09:20 AM. Reason: added legnth of time i had horns on my bike.
Lethal Weapon
Sportster Parts
Jun 17, 2019 08:59 AM
XTonerman
2014-2024 Touring Models
20
Jun 5, 2019 08:32 PM
firemeat
Jul 16, 2016 08:34 AM
ballbreaker69
Apr 20, 2013 08:55 PM
Primo
Sep 17, 2006 12:15 PM
