Need help with CD player
Old Aug 14, 2011 | 07:31 PM
Stang951's Avatar
Stang951
I forgot about all of the problems with making discs for the HK radio. Bohica I am trying your method this time. Sure the hell is time consuming for each cd (I am preserving my original MP3 files elsewhere on my computer.
I am making the playlist in Itunes, copying the files into a separate folder for making the dics, striping the ID3 tags and then using MP3 gain and burning. First one is in the drive now and I will test it when done. HOPEFULLY your method works great. Then I can burn about 6 disks to keep in the bike when I dont have my gps on the bars around town as I normally use that so I dont have to deal with this stuff.
Old Aug 14, 2011 | 07:59 PM
Stang951's Avatar
Stang951
Yep that seemed to have worked. The 30 or so songs that I tried, none were skipped over (at least that I noticed). I would like to add the artist and song information correctly though as now the player shows the track name instead, but I guess you cant have it the proper way with the HK radios.
Old Aug 15, 2011 | 05:15 PM
JohnScrip's Avatar
JohnScrip
More stuff (in need of an update or two, but I'll get around to it - I swear)...
http://www.johnscrip.com/html/blog_f...y_davidson.php
Old Aug 15, 2011 | 06:14 PM
user 8373900's Avatar
user 8373900
Also a slow speed burner here, and I did it as a Data file.
Mark
Old Aug 17, 2011 | 04:31 PM
Homebrew101's Avatar
Homebrew101
That info was the ID tags you stripped, they are not separate files but part of the mp3 file itself
the H-K radio shouldn't have a problem with the ID tags, mine displays the info when I play mp3 discs. Mine does have problems skipping songs on some discs if I don't burn as a data disc
Old Aug 17, 2011 | 04:47 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Buy a mp3 player and don't worry about it!
Old Aug 17, 2011 | 05:05 PM
FlamedFXR's Avatar
FlamedFXR
The H-K is an mp3 player.
Old Aug 17, 2011 | 05:17 PM
santajim's Avatar
santajim
I read a thread a while back to burn as data si I did and got 105 songs on one cd.
Old Aug 17, 2011 | 06:05 PM
Stang951's Avatar
Stang951
Originally Posted by bohica48
I posted this a week or so ago, had the same problem........
After reading through the threads and comments by others I realized that the art work was culprit. I used WMP to remove the art work but still had the same problem with some MP3 files. After a lot of research I found a little program that removes all the art work and other bs that is not needed, an MP3 Tag Remover called ID3KILL. I downloaded it and ran it (very simple to use) and it removed all those unwanted files. I also downloaded MP3Gain and ran it on the MP3 files so I could make the volume levels the same. Burned another CD with WMP and I'm now good to go. NOTE, make sure WMP is set to not "Retrieve additional information from the internet" before burning, this can be found under the Library Options....
This works..PERIOD!! I rode last night for 30 minutes, and NO SONGS were skipped. It has been said in more than one place that the HK radios dont handle the album art well. NO sure why but they dont. I am going to try and keep the ID3V1 information in the files so that I get the right information across the screen. I am leary that it may skip some songs though. We'll see.
Twin Cam - I have a GPS that has a built in mp3 player as well. I use that on trips, but dont like to use it just riding around town. Takes too long to boot up, get prepped all that good stuff. I want discs so that I can keep one in the player and listen when I want to jump on short trips anywhere.
Old Dec 29, 2012 | 06:49 AM
MikeAKQJX's Avatar
MikeAKQJX
I know I may get smacked off the side of my head for resurrecting an 18 month old post, but this seems to be the closest to answer to a specific problem I've been having with my HK Radio and the MP3 issues I've seen.
I know it's an issue with the ID3 Tags, so here goes...
I used a different ID3 Tag Remover to nuke all possible tags. When I do that, I get the filename displayed on the top line and temporarily on the bottom line of the screen AFTER the HK player indicated the current track number I am on. That's kind of OK and has been what I've been living with for a year.
I read up about artwork and figured I would clean all the ID3 tags but re-populate just the Title and Artist to get the Title on the top display line and the Artist temporarily on the bottom display line AFTER the HK player indicated the current track number. Here's what I have...
TITLE TAG: And We Danced
ARTIST TAG: Hooters
FILENAME: Hooters - And We Danced.mp3
Everything else is nuked from an ID3 Tag perspective. Then I get this on the display AFTER the track number...
TOP: ***A
BOTTOM: ***H
I have been experimenting and just cannot get this clean and correct for what I want.
Bohica48 - You seem to have the the best knowledge on the whole ID3 tag vs. HK CD/MP3 display issue that I have read so far, so this is for you (and anyone else that can answer this):
What ID3 tag format are embedded in your MP3s?
What tags do you keep to display Title and Artist?
What tags must be cleaned up or removed?
As an aside: I am using MP3TAG v2.54
**Thanks in advance for any assistance here**
