Cigarette lighter
Old Jul 12, 2011 | 05:26 PM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
If you cut the lighter plug off,that may be your problem !!
Old Jul 12, 2011 | 05:28 PM
outlaw481's Avatar
outlaw481
Originally Posted by boatsswain
The plug on the back of the lighter? If so i checked before i put it back together. I also checked to a good frame ground, read .01 volts. Everything else works
There should be a plug in the fairing that the two wires for the cigarette lighter come from...possible it came loose or is corroded. If the bike still starts and has power everywhere else, its a wiring problem for that circuit only. Take an ohm reading through the fuse...if its still good, then might as well open the fairing up and work back from the lighter to the main harness connector.
I'd definitely double check the work I did and make sure my splice was 100% and ALL the fuses were good first though.
upstate tim's Avatar
upstate tim
Never mind.
Short on sleep
Got a light?
Old Jul 12, 2011 | 06:06 PM
KACook's Avatar
KACook
If you cut both wires at the same time with the key on, then the fuse is blown.
Did it have power at the lighter before you started??
It sounds like a bad fuse one way or the other.
Use a TEST LIGHT to check both sides of EVERY fuse in the fuse block.
Good Luck
Old Jul 12, 2011 | 06:11 PM
HalfFast's Avatar
HalfFast
Did you have power to your lighter before you started this project?
Old Jul 12, 2011 | 06:46 PM
boatsswain's Avatar
boatsswain
3rd Gear
now that i think about it the power was on, but i checked the fuse and it is good, so frustrating
Old Jul 12, 2011 | 07:38 PM
outlaw481's Avatar
outlaw481
I'd check ALL the fuses...just to be safe...
Old Jul 12, 2011 | 07:53 PM
stuart1270's Avatar
stuart1270
Check the other fuses I just blew my fuse and it was not the one I thought it should be. For some reason it was a different fuse. Also my horn and signal lights went out.
Old Jul 12, 2011 | 08:00 PM
SG Mike's Avatar
SG Mike
Take the wires off everything and measure one side to a good ground to see if you have voltage. If not then work your way back from there.
My guess is that your splice is bad somewhere or you've pulled one end of the wire out.
Also I would go to radio shack and buy the slide on clips and use the extra lugs on you lighter so that you don't have issues later.
Mike
Old Jul 12, 2011 | 09:20 PM
Dalejb's Avatar
Dalejb
The lighter is fused on the PA fuse. Not the one you might think. If the fuse is blown the ACC button on the dash will not light up either.
