15A Brake Fuse Blowing
A fuse is a current limiting safety device which blows when current in excess of the rating passes through, so the bottom line is that the only way you can blow a fuse is by having "too much current"
So, why do people talk about grounding as the issue? All electrical devices have an inherent resistance in them, and the current flowing through this device against this resistance is what gets the power to the device to do what it is designed to do.
This relationship is defined by the most classic of electrical laws called Ohms Law, which states V = I x R, where v is voltage (fixed at 12vdc on a bike), I is current and R is resistance. When the device designer builds the device they know what the total resistance of the device is so they can calculate the size of he fuse required to protect that circuit.
So, what does a grounding issue have to do with this. Well, if a wire, which should be totally isolated from ground inadvertently becomes connected to ground, then this offers an alternative flow path for the current, rather than through the device (lights in your case). Current will always flow through the path of least resistance, and looking at the formula above you can see that if a wire is directly connected to ground resistance is, essentially zero, which means current MUST be infinite!
How do wires get connected to ground? Typically something gets pinched during assembly and the insulation is broken through with the bare wire then being exposed to a sharp metal edge of screw. There are other ways but this is the most common by a long way. Another common cause is the switch assembly itself being damaged internally and connecting the live to ground internally.
The fact that you are blowing a 20A immediately would indicate a grounding issue, I agree with that, as it appears as though you have current well in excess of the specified limit. Fuses will withstand momentary current surges
Low beam current draw 1.5 amps (stock halogen is 4.9 amps) High beam current draw 2.3 amps (stock halogen is 5.5 amps)
Passing lamps (pr) current draw 1.4 amps (stock halogen (pr) 4.0 amps)
So it seems to me that my passing lights are only drawing maximum 2.3 amps the way I see it. So where is the remaining amps current coming from?
I kept blowing the fuse for my running lights and tail lamp. It was a chaffed wire behind my headlight rubbing against the fork head tube.
Mine began to require very hard pedal pressure to light the lamp. This was another one of the possible failure symptoms.
My dealer replaced hundreds of them and told me that mine was the only actual failure they saw during the recall period. They moved me up to the front of the line for replacement.
Look into that if you haven't already.
