dna wheel
Old Jul 20, 2011 | 10:46 PM
ice793's Avatar
ice793
Default dna wheel
For those that might know.... will i need any spacers when i do the install? BTW its a 21 fat spoke dna wheel. Any advice is appreciated
Old Jul 21, 2011 | 01:00 PM
ice793's Avatar
ice793
(bump).... so many threads get started
Old Jul 21, 2011 | 01:24 PM
dusty6700's Avatar
dusty6700
If you ordered the wheel for your make and model, you should only need the stock spacers. If your bike has ABS, you need to make sure the wheel a that ABS bearing installed.
Old Jul 21, 2011 | 03:06 PM
pit1600's Avatar
pit1600
+&. Nice wheels and tubeless!! My best friend have them on his Road King.
Old Jul 21, 2011 | 03:28 PM
markzx7zx7zx7's Avatar
markzx7zx7zx7
just put a 21 front on my electraglide, with abs, what i done was pull the bearings from the dna wheel and install the stock bearings in place and all stock spacers worked perfect, the reason to change the bearings because the ones from dna are thicker than the stock bearing so stock spacers wont work, ps go ahead and run a tube in these because they leak you can easily see why where they drill the hole for the valve stem is inbetween the spokes no rome to tighten down the valve stem to seal it
Old Jul 21, 2011 | 04:09 PM
ice793's Avatar
ice793
yes it was ordered to the make of the bike and i told them it had abs. how do i know if the correct bearing was installed?
Old Jul 21, 2011 | 06:36 PM
BenRK05's Avatar
BenRK05
I just ordered the same rim last week. I had a white wall tire in the garage that I found at a mom and pop. I was told that they were hard to find in a 21. I also got a really good deal on matching chrome rotors for $99. Its going to be a long 3 to 4 weeks till they show up.
Old Jul 21, 2011 | 11:02 PM
ice793's Avatar
ice793
ben my wheel only took a couple weeks so hopefully yours won't take long. got mine on today so far im impreesed love the look and ride.
Old Jul 21, 2011 | 11:03 PM
ice793's Avatar
ice793
need to get the rotors to complete the look. it's a shame the 360 brake is'nt compatible with abs yet that would really clean up the front end.
Old Oct 11, 2016 | 05:22 PM
Deltyree's Avatar
Deltyree
Default Dna fat spoke install with abs
I was wondering all I need is the abs bearings or do I also need the OEM axle sleeve? I'm installing.this wheel on a 2008 street glide with abs. Thanks
