Help me fix my SE baffle
Old Jul 27, 2011 | 03:07 PM
steelerdude1's Avatar
steelerdude1
Default Help me fix my SE baffle
I have Screaming Eagle Slip-ons and I have a squeaking baffle in the left pipe. The model # of my pipes is 64926-99 "not for road use". I have finally tracked down my source, now I'm not sure how to fix it.
I tried putting a tack weld on the outside end of the baffle, but it didn't help. If I shake the pipe, I can hear something small like rust particles rolling around, and I can't shake them out.
Anyone else experience this? were you able to fix it?
Old Jul 27, 2011 | 05:47 PM
DrPlastic's Avatar
DrPlastic
I would cut the weld beads that hold the baffle in with a dremel or something similar. Then remove the baffle, clean out the pipe then either reinstall baffle or replace with Full sac or something similar. you can just drill a hole in the bottom and install a simple pop rivet or something similar!
BigJess510
Exhaust System Topics
Aug 28, 2016 07:55 AM
jus2anoyu
Sep 22, 2013 07:06 PM
bads1buell
Feb 10, 2013 06:02 PM
SharkBite
Jun 24, 2012 08:20 PM
dawg
Sep 14, 2007 06:15 AM
