Hate to sound stupid but could you splain this technique, can always use an extra secret weapon in the toolbox.
How I have done it is stuff the gauze pad in the cylinder when the piston is up, then put some grease on the pad while it is in there, then put your finger or something in there and smear a seal to the bottom of the hole , then when you are done cutting, scrape out all of the shavings you can then pull the gauze out.
Sure, used this method so many times on early shovels that used helicoils in the spark plug holes and on a buggered up Evo or two. Make sure the piston is top dead center. It keeps the gauze or cotton, whatever you use, from dropping out of reach. Then coat the gauze pad with bearing grease. Shove it into the spark plug hole. Push it right in to the bottom of the hole. It won't go far with the piston top dead. Then add more grease blob to the hole. Then as your tapping for the heli coil, any shavings is trapped in the grease. When done, use a small pair of needle nose or what I use is a long surgeons tweezer and carefully pull out the grease and shavings covered gauze. Done deal.
Thanks for the explain, I'm all about the field expieient machine tricks, they'll make or break ya. The air thing works great too, I made a rig with a simple ball valve and piece of scrap hose, so you can set everything up and then turn on the air when you get ready to tap.
I do sort of the same thing but I move the piston down a little ways and then stuff the pre greased gauze in the hole, take a small dowel and spred the gauze out some remove the dowel and move the piston up so that the gauze fills the combustion area...then I put a blob of grease on the tap tip treads (to catch most of the chips) and run in/out the tap...then I look in the hole and try and fish out the extra metal chips with a pair of surgical plier thingys move the piston down a little and use the same pliers to pull out the gauze...put in a new piece of gauze and run in the helicoil..and try and carefully break the end off of the helicoil with the same pliers if that doesn't work just break it with a dowel and reach in and pull the piece of metal out and then pull out the new piece of gauze (sometimes you need to use a small piece of coat hanger of something like it to help the gauze not get caught on the end of the helicoil...sounds harder than it really is....just take your time and it will all work out fine...Oh, and don't turn the helicoil in to far...you don't want it to be below the bottom of the threads (usually not an issue)...
