2011 SG Clutch Adjustment ?
Old Jul 29, 2011 | 11:59 AM
Stiggy's Avatar
Stiggy
1/2 to 3/4 too. And I 'seat' the rod 3 or 4 times so that I get a accurate 'seat' beforehand.
Old Jul 29, 2011 | 01:22 PM
jdunn01's Avatar
jdunn01
Copied from Other Members post. I just copied and created a word doc to have for reference.
Clutch Adjustment The Easy Way
Here is an almost fool proof method for clutch adjustment. It takes the guesswork out of the "feel" for the adjuster.
Once you have opened up the derby cover and are ready to proceed...
1)Collapse the adjuster on the cable sleeve all the way.
2)Pull the lever against the bar and hold it there with slight force.
3)Turn the pushrod adjuster bolt in while holding the lever against the bar lightly until it starts to force the lever away for some distance. (Do this more than once to get the feel). While keeping light pressure on the lever back the adjuster bolt out just until the lever touches the bar again and then another little bit, about 1/2 turn , then lock it.
4)Adjust the cable freeplay at the lever for 1/16" free play.
You should be good to go .
Always adjust the clutch on a cold bike for best results.
**It's better to adjust the clutch so that it starts to grab at least an inch or more from the bar for complete disc separation, which translates into better/quieter shifting. Using this method, you can "feel" where the lever is going to grab with a little practice.
Buy yourself a cheap 11/16 offset box end wrench. This makes the perfect tool for the adjuster lock nut. You can then use an Allen wrench inside the box end of the wrench.
You can also see "clutch adjustment by the book" below
Clutch Adjustment Technique By The Book
Let's go over the basics of clutch adjustment on late motorcycle models.
Ideally, you want the motorcycle to be on a lift or stand. The procedure can be done on the kickstand but, some primary fluid may leak out.
Back off the cable adjuster until the adjuster is fully collapsed.
Remove the derby cover and set aside.
Loosen the clutch adjuster lock nut two turns.
Turn the clutch adjuster in until it seats against the clutch release. Seated means that it is touching but not pushing against the release. At this time the clutch lever should have very little play.
Back the adjuster out 1/2 to 1 full turn from seated. Repeat this several times to get all the play out.
Lock the adjuster nut down while holding the adjuster from turning.
Work the clutch lever several times before adjusting the free play at the cable adjuster. Adjust the free play to 1/16" to 1/8" as measured at the pivot. I usually add just a little slack as a personal preference.
Work the clutch several times to make sure operation is smooth and no binding in any part of the travel.
Install the derby cover after topping off primary oil if needed.
Perform a test ride and adjust the free play as needed to get the engagement and release points correct.
If you cannot adjust the clutch free play with the cable adjuster, the cable may be stretched or frayed. If the cable has been replaced, the wrong cable may have been installed.
A worn or warped clutch pack will often feel as if the adjustment is bad because it tends to make the release and engagement jerky. If after adjusting the free play you still have clutch operation problems it may be time to take a look at the clutch.
dajogejr
Jul 25, 2016 06:29 PM
Lang47
Aug 26, 2013 12:08 PM
Grizcat68
May 16, 2011 09:17 PM
ddan1130
Jun 21, 2010 07:43 PM
JollyRogers
Sep 9, 2006 10:47 AM
