2010 "103" backfiring
Old Jul 29, 2011 | 10:05 PM
CT-Bagger's Avatar
CT-Bagger
Default 2010 "103" backfiring
I have done mods to my Limited with a PCV ( set-up by fuel moto and my local tuner with the same results ) Vance & Hines Power Duals, and Vance & Hines twin slash ovals.
The bike runs great, sounds great, but between gears at low rpms the bike backfires.
This is especially true when it's real hot out.
I have added 5% more fuel to the map at 2% throttle between 1500 - 3000 rpm with a slight improvement.
Is anyone else having this problem?
Old Jul 29, 2011 | 10:43 PM
Gitarded's Avatar
Gitarded
Mine does the same thing at times. I have SERT, stage 1, Rush pipes no cat and V&H monster ovals. Did you remove the cat with those pipes?
Old Jul 29, 2011 | 11:04 PM
user 8373900's Avatar
user 8373900
put 12's or even 15's in the 0 throttle position all the way down. It will stop. OR you have an exhaust leak.
Mark
Old Jul 29, 2011 | 11:30 PM
CT-Bagger's Avatar
CT-Bagger
Mark
I have tried up to 30's in that column.
Old Jul 29, 2011 | 11:55 PM
ke5rbd's Avatar
ke5rbd
Try unhooking the PCV. If it still does it look for an exhaust leak. My even try a Zero map first.
Old Jul 30, 2011 | 12:01 AM
user 8373900
Then my money is on an exhaust leak somewhere.
Mark
Old Jul 30, 2011 | 06:00 AM
rossn2's Avatar
rossn2
No issues on my 11 FLHTK, but running a SE Supertuner and had bike dino tuned same time...
surfnorthwest
2014-2024 Touring Models
Jul 26, 2014 03:18 PM
stevenm_86
Apr 16, 2013 04:07 PM
Crask6969
Feb 28, 2012 03:56 PM
GhostRider58
Fuel Moto / Jackpot Mufflers
Jun 30, 2011 08:31 AM
motorsgt8
Feb 5, 2011 02:51 PM
