Screeching primary
Old Jul 31, 2011 | 08:18 AM
epsmith's Avatar
epsmith
Default Screeching primary
I was on my way home from work going about 40 mph and I heard a god awful screeching noise coming from my primary. I immediately downshifted to neutral and the noise went away and came to a stop on the shoulder and shut the bike down. I start get that sickening feeling and begin to think the worst crank shaft bearing went **** up.
After waiting about 15/20 mins I start back up no noise shifted to first and limped about 100 feet no noise went 2nd noise started back up back to N no noise so this leads me to believe that the problem is the bearing in the clutch pack is toast, but I 'm still weary about the crankshaft bearings.
Had the bike trucked home. Only thing I have checked for so far is primary oil and is ok so I didn't cook the bearings from lack of oil.
Any and all advice would be appreciated.
05 Roadking 16k miles
Old Jul 31, 2011 | 10:04 AM
dawg's Avatar
dawg
Clutch hub bearing or inner primary bearing possibly? Best thing to do is pull off the inner primary and check all the bearings and your rotor (just replaced a bad one on an 05). While you're in there, replace all the seals.
Old Jul 31, 2011 | 11:29 AM
speakerfritz's Avatar
speakerfritz
if your going to do the work yourself, shoot me an email.
Old Jul 31, 2011 | 12:04 PM
69cj's Avatar
69cj
If it was a crank bearing the odds are the noise wouldn't go away in neutral. The engine is still spinning. Dawg has you going in the right direction.
Mark_FLHTCU
Twin Cam Motors
13
Feb 22, 2020 05:51 PM
Xrivera31
Jun 29, 2017 08:31 AM
watindes
EVO
Aug 30, 2013 06:52 PM
lowrider6
Jun 26, 2013 08:47 AM
jpooch00
EVO
Mar 19, 2012 05:46 AM
