Engine Issue?
Old Jul 31, 2011 | 06:37 PM
PappyUSMC's Avatar
PappyUSMC
Default Engine Issue?
2009 Ultra
Start the bike, Idle seems like it is about to stall then RPMs go up.. then back down, when in 1st gear, does the same, have to ride the clutch just right.
Check Engine light came on, then did not come back on on a subsequent restart.
Used Fuel Cleaner
Clutch Adjusted this weekend.
Air Filter Cleaned
New Plugs 10k ago
Fluid Change 2k ago
93 Octane Gas, various sources
PC5 maps still loaded.
This is a recent change in bike behavior.
50K up to this point and running strong.
Ideas?
Old Jul 31, 2011 | 06:41 PM
luc.who's Avatar
luc.who
First thing I would do is to test it without the PCV and then go from there.
Old Jul 31, 2011 | 07:23 PM
69cj's Avatar
69cj
I would also start using a minimum 91 octane fuel.
Old Jul 31, 2011 | 07:32 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
check engine light means it threw a code it may be stored,if it is at start up the light will go off then come back on for a few more seconds after start up.dought it has to do with octane,more than likely a sensor is starting to go goofy.
Old Jul 31, 2011 | 07:42 PM
PappyUSMC's Avatar
PappyUSMC
Typo on my part...
I use the highest octane.. 93
Old Jul 31, 2011 | 08:13 PM
TexasVet's Avatar
TexasVet
Originally Posted by PappyUSMC
2009 Ultra
Used Fuel Cleaner
Air Filter Cleaned
New Plugs 10k ago
Fluid Change 2k ago
Ideas?
Just an idea, what about the fuel filter? Just changed mine at 27k miles and the manual states to change at 25k and mine was pretty much clogged up.
Old Jul 31, 2011 | 09:43 PM
speakerfritz's Avatar
speakerfritz
probally heat related...your are probally running too lean of a low rpm mixture....also could be your engine temp sensor (mounted at the rear of your forward heads). Un plug the heat sensor and if the bike runs better, you either are running too lean or you need a new sensor.
Old Aug 1, 2011 | 04:54 AM
PappyUSMC's Avatar
PappyUSMC
I have a good map from Fuelmoto that runs rich to offset some heat. I also have a leaner map with a toggle switch. Tried both.
I like the fuel filter idea, I will give that a whirl.
Thanks.
Fusion777
Apr 9, 2018 07:25 PM
mike513
Aug 28, 2017 07:08 PM
Fedoraman
Dec 14, 2013 05:17 PM
Sporty-ROL
Apr 25, 2012 11:00 AM
dr.phatkins
Apr 9, 2007 11:01 PM
