temperature concern
Old Aug 3, 2011 | 03:16 PM
ajohnston78's Avatar
ajohnston78
Default temperature concern
At what tempereature do you guys get concerned about oil being too hot?
Old Aug 3, 2011 | 03:26 PM
PWFD's Avatar
PWFD
Not to sound like an a$$ but I dont get concerned. With the current way oils are made today I think they can handle about anything we through at them. I toss new fluids in every 3K and just enjoy the ride. I'm no expert by any means so I will be interested to see what other have to say. I could be TOTALLY wrong in my assessment.
Ride safe...
T
Old Aug 3, 2011 | 03:29 PM
NoBoldRider's Avatar
NoBoldRider
I agree with what you said. It gets pretty hot here in AZ, and I've never had any problems. I change the engine oil about every 2,500 mi. particularly in the Summer.
Old Aug 3, 2011 | 03:32 PM
07RoadHawg's Avatar
07RoadHawg
I did a dyno tune and put on an oil cooler when I did my motor work. I figure that's all I can do so I might as well ride. Hasn't let me down yet with 110* heat.
Old Aug 3, 2011 | 03:35 PM
KWC6's Avatar
KWC6
When it gets this hot, I ride my Honda VTX water cooled bike.
Old Aug 3, 2011 | 03:42 PM
'05Train's Avatar
'05Train
Harley sells the same bike with the same warranty in both Alaska and Arizona. I don't worry about heat. Ever.
Old Aug 3, 2011 | 03:44 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
When the oil gets around 260* I would start looking at ways to keep it below that.
Kevin
HDForums Scavenger Hunt Contest
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Aug 3, 2011 | 03:49 PM
m361's Avatar
m361
I've read that HD says under 300 and your fine. Highest I've seen mine go is 261 and that was on a 97 degree day in slow traffic (103" and no cooler). I figure as long as I run full synthetic it'll be ok.
Arizona's Avatar
Arizona
With modern synthetics I don't fret over it too much. I am currently taking steps to help it run cooler, but for the first 50,000 miles this bike was totally stock and I never had an issue even in this punishing heat of the desert southwest.
Stock this bike usually ran 240-260* in summer when cruising on a warm/hot day. On a cool evening it would run 230*. On two occasions it got to 275* once and 280* another time. Both times were after a slow (15 mph) uphill ride up the 2.5 miles of dirt road (uphill about 400' elevation change) to my house. Due to the dirt I have to take it slow n easy so the bike warms up in doing so. When I get off the bike I check the dipstick thermometer usually.
I run Redline 20W-60 so I'm sure this oil will take those temps in stride, but ideally I want it to run cooler, so am in the midst of doing a Stage I upgrade with a PC-V, V&H Powerduals and a SE Ventilator air kit (still running stock mufflers). I'll update you on the cooling results when it's all been done. An H-D oil cooler will be next to complete the entire package...
Old Aug 3, 2011 | 03:50 PM
mkguitar's Avatar
mkguitar
Same here.
If you measure temp, where are you measuring...
Twin Cams spray oil at the underside of the pistons to aid in cooling, so that portion of oil gets way hot.
I have had (twice, on my Evos) oil get hot to the point where my oil pressure dropped drastically. I changed it as soon as I could.
It is counter-intuitive, but higher revs, means more oil volume and pressure, which carries more heat away from the motor- so don't lug or idle for long periods.
I use syn 3 and look to change every 2500~3000 miles, aside from the heat we also have alot of dust here in AZ
mike
