tourpac addition
Old Nov 14, 2006 | 10:55 AM
vailtl's Avatar
vailtl
Default tourpac addition
I received my tourpac installed it on 07 road glide.
Question, Is there an extension for the lights (ultrapac) and
antenna wire I am about 6" short of pluging these in.
For now I just plugged in an old hidden antenna I had
and placed it under the pac liner.
Thanks
[IMG]local://upfiles/6572/D154DF5154D447FF93DD8437C61BF181.jpg[/IMG]
Old Nov 14, 2006 | 01:10 PM
gunrunner's Avatar
gunrunner
Default RE: tourpac addition
Antena relocation kit, and your bike has a wiring plug that comes out near to the end of the seat it should be long enough
Old Nov 14, 2006 | 02:45 PM
vailtl's Avatar
vailtl
I did manage to pull the light wires out from under the metal plate that was bolted down inside the
pac. I pushed it through the hole and just managed to plug in to the one that is under the seat.
It is stretched to the limit I wish I had a few more inches so that it is not so tight.
I might have to cut the wire and splice some in, cover it with shrink tubing.
I should not have to do this. Seems like there should be an extension one could bye.
Thanks
Old Nov 14, 2006 | 02:52 PM
pointswhat's Avatar
pointswhat
Are you sure that the cable under the seat isnt wrapped around something? I know there is more than enough slack in mine.an the connection is inside the tourpack under the liner. I would make sure before I spliced into it.
But if your gonna splice in a mod I did was add a power outlet in the tourpack to charge an Ipod or cell phone. Just a thought.
vman99
2014-2024 Touring Models
Jan 8, 2019 04:06 PM
tankplunkett
Apr 17, 2013 04:35 PM
BigTasty
Apr 23, 2011 03:04 PM
heavymetalthunder
May 15, 2008 08:52 PM
agapsdiver
Nov 2, 2007 11:03 PM
