stereo
Old Jul 12, 2005 | 09:34 PM
gribas's Avatar
gribas
6th Gear
Default stereo
Have I now put this in the correct post
As you all know I'm new here, so I hope I posted in the right spot. My question is-- on my 04 road glide there is a switch to turn on the speakers. It is a 2 position switch to use rear speakers if you add the tour pak. I like the look of the bike with just a back rest, so my questions are (1) where are the speaker leads coming off of that #2 position on the switch (2) can I get a Harley wire harness to plug into those leads (3) most car stereo is 4 ohm--Harley is 8ohm is that a big deal and lastly (4) has anyone done something like this before. my idea is to use a set of 2in clamp on speakers on the handle or crash bars. I have installed my share of car systems in the past- amps, subs, twets, mids, etc, but wanted a little help before I tear into a perfectly good bike
Thanks Gene
Post #: 1
As you all now know not only am I new here, but I'm also an idiot when it comes to computers--- So I hope I have now put this question in the right place
Old Jul 12, 2005 | 11:49 PM
pilot1996's Avatar
pilot1996
Default RE: stereo
Don't know the question on the switch. But I can tell you this, the 8 ohms of impedence that the MoCo has in their speakers is what prevents them from being worth a damn. Hogtune sells speakers that are 4 ohms, and they are superior to the HD brand, by a long shot.
Go with the 4 ohm in th back, you will replace the ones in the front pretty quickly. Look into www.hogtunes.com
Mac
Old Jul 13, 2005 | 10:38 PM
gribas's Avatar
gribas
6th Gear
Default RE: stereo
Thanks for the info, I'll click the link, and hopefully find some solutions. Keep you informed if I find something cool. Thanks again--Gene
Old Jul 14, 2005 | 01:11 AM
Papamte's Avatar
Papamte
Default RE: stereo
Gene, my friend has an 04' Road Glide and would like to add the rear speakers also. He says though that to use them with the Glides radio , that you have to remove the radio and have H-D install a new plug in to the radio for the extra speakers ( or something like that ). This is so that you can use the rear speaker controls. If you simply splice into the harness, you could only control the balance and all speakers would play at the same volume. I would call the dealer and ask about this before you make up your mind about the install.
Old Jul 14, 2005 | 08:52 PM
gribas's Avatar
gribas
6th Gear
Default RE: stereo
That figures, it seems like Harley is really good at getting you into their dealers to by their parts. I thought about using my knowledge of car systems to build my own, but I would lose the handlebar controls and most likely mess up the look of the bike in someway. I'll research more, and post back if something neat pops up. In the meantime, any other tips would be great.
jbasile
Oct 23, 2016 07:17 PM
easy-wyatt
2014-2024 Touring Models
13
Apr 24, 2014 10:06 AM
traveler
May 25, 2012 08:15 PM
hdman6
Apr 8, 2012 07:02 AM
gribas
Jul 10, 2005 09:01 PM
