lower fairing speak question
Old May 25, 2012 | 10:45 AM
traveler's Avatar
traveler
Default lower fairing speak question
I'm thinking about adding speakers to my lower faiirngs, and have a question:
I added the speaker switch to my bike, which is what the Ultra's have for turning the rear speakers on and off, and it is wired in. I added it, as I didn't like seeing the block off plate, and I like the look of having a full bank of switches.
So, with the lower fairing speakers, how would I wire them in? Do I need an amplifer?
The ones I am thinking about are the CVO ones.....prices are real reasonable online, just have to get the outer "boxes" painted Sedona Orange.
Thanks in advance,
~Joe
Old May 25, 2012 | 03:29 PM
Harleypingman's Avatar
Harleypingman
Joe,
Yes, you'll need an amp. How to wire the speakers in the lowers offers a couple of options: (1) access the rear speaker pinouts of the HK radio currently unused on your bike; (2) use a four -channel amp like the RF PBR 300x4 that takes a two channel signal and splits it into four channels--no fader control, but you aren't using the rear speaker pin-outs of the HK; and, (3) depending on the ohm ratings of the speakers used, wire the two pairs of speakers in series or parallel to conform to the amp's requirements.
Carl
PS: The speaker switch doesn't turn the rear speakers off on and Ultra.
Old May 25, 2012 | 05:16 PM
traveler's Avatar
traveler
okay, thanks for taking the time to reply.
What does that speaker switch do then?
~Joe
Old May 25, 2012 | 06:42 PM
GLACIERPEARL's Avatar
GLACIERPEARL
From another thread.
Originally Posted by SteelCityScooter
Take the time to read your owners manual, the "speaker" switch on the inner fairring cap is for switching audio sources between the speakers and the helmet headsets.
"Headset A"All the way forward (no light) Everything through the headsets (Radio, CB, Intercom)
"Headset B"Middle (light on) Radio through speakers,CB and Intercom through headsets
"Assy Enable"All the way back (light on) Radio andCB through speakers, Intercom through headsets.
GND is for the ground wire for the little ight in switch
Your Intercom Audio will only work through the headset speakers to maintain privacy.
Speaker Fading (front to rear) is done through the softkeys on the radio, or by using the left volume switch on the handlebar. (Push in till it goes to fading screen on radio, then up or down to move the audio front to rear.)
To the original question of the thread.
The "Speaker" switch on the fairing cap does not have audio signals attached to it, it is connected to the radio control circuits (follow the wires back through the wires from the switch, then through the "interconnect harness" and you will seee they only go to the radio and not the speakers)
To enable the rear speakers when installing a tourpak and then installing rear speaker PODs, you will have to have the Dealerturn them on through the radio by flash downloading the ECM. (The Ultra is the ONLY model that comes with the rear speakers, factory enabled. in the HK Radio)
So tapping on to any of the wires there will not get done what you want.
Old May 25, 2012 | 08:15 PM
traveler's Avatar
traveler
okay....cool. THANKS.
I put it in there....as I stated, becasue I'd rather have a switch then a blank plate to remind me of the option I didn't get when it was new.
~Joe
Sire2Twins
Audio Systems
May 8, 2013 01:36 AM
mccstevie
Sep 2, 2012 05:11 PM
jgcable
May 4, 2010 02:43 PM
jeff194
Oct 24, 2006 12:06 AM
wjl24
Sep 10, 2005 05:35 AM
