Wheel balancing question.
Old Aug 29, 2011 | 10:38 PM
steelerdude1's Avatar
steelerdude1
Also, Make sure your front wheel is aligned correctly. not sure if there is any difference from my 06 to yours.
Old Aug 30, 2011 | 01:34 PM
BenRK05's Avatar
BenRK05
The wheel is balanced and true. I check on a static balancer. One thing that is wrong the left wheel spacer is not the right size. Stock size is .968 width I have a .964 width. Would that little of a size difference throw of the alignment? I do have the proper spacer waiting for me at a local shop. Thanks guy for all the ideas and suggestions.
Old Aug 30, 2011 | 02:15 PM
parabellum_9x19's Avatar
parabellum_9x19
Man I doubt it...four thousands of an inch is a really small amount...
Old Aug 30, 2011 | 06:58 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
im betting ther tolerance on the spacer is biggere than 4 thous.
Old Aug 30, 2011 | 09:06 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Forget dyna beads.
You have checked the static balance and that's not the problem. That .004 difference can possibly be an issue over time so I would take care of that variance. Remember that you have changed the geometry of the bike with that diameter front wheel. If others have that wheel and have success, all you need to do is make sure your wheel spacers are equivalent, and the wheel is aligned. Small inconsistencies in the tire tread and wear can actually cause crazy vibrations at only certain speeds. Make sure that tire is not micro-cupping. Also make sure your wheel bearings are still at spec. Hope you find the cause.
Old Aug 30, 2011 | 09:49 PM
SH_01FXDWG's Avatar
SH_01FXDWG
How much air you running? Bump it up to 40 psi see if that helps. Also raise the rear pressure up a bit.
Old Aug 30, 2011 | 10:02 PM
BackAt5O's Avatar
BackAt5O
There's no way .004" in spacer thickness would cause this problem. The front ends on these beasts just do not run this tight of tolerance. It is most likely a tire/wheel problem. Is the tire mark lined up with the valve stem? Have you tried rotating the tire 180 degrees on the wheel and balance again? I would not rebuild the whole front end before I tried a different tire.
Old Aug 30, 2011 | 10:29 PM
Bluehighways's Avatar
Bluehighways
Use the Harbor Freight Motorcycle Wheel Balancing Stand Item # 9848. with the 20% Discount Coupon that is in the back of every bike and car rag it's like $40. Money well spent in my case.
Old Aug 31, 2011 | 01:12 PM
BenRK05's Avatar
BenRK05
Blue highway that's the balancing stand that I have. I went and picked up the correct wheel spacer. Ill install tonight and see if that was the cause. Thanks everybody.
Old Aug 31, 2011 | 08:18 PM
vickers1's Avatar
vickers1
Don't forget to post with the solution.
speederman
Mar 19, 2017 07:41 PM
DG Racing
Wheels/Tires
Jan 5, 2015 10:43 PM
todd493
Sep 17, 2013 08:14 PM
John Bernard
Aug 4, 2010 04:45 PM
jneubig
Dec 5, 2007 04:21 AM
