Verdict on draggin' baggers
Old Nov 18, 2006 | 12:10 AM
AtkRWC's Avatar
AtkRWC
Default RE: Verdict on draggin' baggers
ORIGINAL: jkirisits
ORIGINAL: AtkRWC
I know there has been some discussion on this matter, but what about belt tension issues? Anyone had a problem, did you readjust the belt during installation or leave it alone?
shouldn't effect the belt at all
I figured since the service manual gave different Drive Belt deflection specifications with the bike on the stand or up in the air it had to do with something with the position of the swingarm. Seems the DB system could change that factor since it has something like a 4" movement.
Old Nov 18, 2006 | 12:20 AM
kruzin's Avatar
kruzin
I have logged over 500 miles on mine so far and really like it. The purpose of having it? Well it allows me to lower it for city riding giving me better control by being able to flat foot the ground. It also lowers the center of gravity, which helps in handling. Then when hitting the highway just the touch of a button I am back in the cruising position.
Yes, there were some start up problems but I tell you what Tony has gone out of his way to make things right.
Old Nov 18, 2006 | 12:42 AM
ironhorse's Avatar
ironhorse
I have over 1 K miles on mine now, yes it is a sort of novelty item, but I like to be able to adjust on the fly. I did receove a bad dump valve and a new one was on the way right after I left a message.
IronHorse
Old Nov 18, 2006 | 01:14 AM
jmorton10's Avatar
jmorton10
I don't think I'm going to leave my DB setup on, the ride is a little too stiff for me after trying it for a while.
I had Progressive 440's on it before & I will either reinstall those or maybe try a set of Works shocks.
~John
If anybody wants to buy my DB setup, email me:
jmorton10@myrealbox.com
Old Nov 18, 2006 | 02:55 AM
joemag94's Avatar
joemag94
6th Gear
I love the novelty. It is cool to slam it, but I'm also wondering if I'm going to leave mine on. It is stiffer and can get harsh on rough roads. I think the problem is the valving on the shocks. As I understand they were designed for a Corvette. A much heavier vehicle.
Old Nov 18, 2006 | 08:39 AM
jmorton10's Avatar
jmorton10
An air shock setup is never going to give as smooth & cushy a ride as a high quality correctly valved standard shock.
Both Progressive & Works make shocks that dramatically improve the ride quality of any Harley over the stock air shock setup.
~John
Old Nov 18, 2006 | 11:35 AM
Branded's Avatar
Branded
ROFLMFAO
When donkeys fly from my a$$!!!
ORIGINAL: PhilM
Did they become a site sponsor yet?
b1rider
"The Georgia Crew"
13
Sep 29, 2011 06:12 PM
neilgehrke
Apr 11, 2011 06:49 PM
CountryD
Air Suspensions
Jan 19, 2011 08:20 PM
chromedome
Sep 3, 2010 12:27 PM
BaggerDave
Jan 18, 2006 12:27 PM
