Rough Idle
Old Sep 5, 2011 | 10:43 AM
adaroadglidelemke's Avatar
adaroadglidelemke
Stage I
Default Rough Idle
What to do? My 09 Road Glide just came out of a 2 year storage with a dead battery. Replaced battery, reprogrammed my V&H Fuel Pak(never buying another one), and I have been running rough before and after I did these things. I doubled checked the program and it is correct (from the web site). Does anyone have any ideas? Again, at roughly 3.5 - 4K RPM the idle goes rough almost dying then comes back up once I let off the throttle? 2009 Road Glide, Thunder header H 2 into 1, Vance N Hines Fuel Pak and a stage one air cleaner. Any help would be great!!
Old Sep 5, 2011 | 10:48 AM
Guntoter's Avatar
Guntoter
Did you completely change the fuel? Bad gasoline, which after 2 years of sitting, the gas will be bad, could cause those problems.
Old Sep 5, 2011 | 10:53 AM
drukanfu's Avatar
drukanfu
Try new plugs and get some new plug wires for a start.
Old Sep 5, 2011 | 10:55 AM
DTTJGlide's Avatar
DTTJGlide
New plugs & new gas for a start.
Old Sep 5, 2011 | 11:00 AM
Dionicio's Avatar
Dionicio
Use some Fuel Injector Cleaner also.
Old Sep 5, 2011 | 11:16 AM
mrfikser's Avatar
mrfikser
if you are accellerating hard and it sputters etc. and then you let off of it and accellerate again and its ok for a few seconds and sputters again, it could be a clogged fuel filter or a restriction somewhere else in the fuel system, and maybe the hose inside the tank has a leak ...
BDSUSA
Jul 24, 2014 05:09 PM
riflecoach
Aug 26, 2011 09:17 PM
SciFiGuy
Oct 17, 2010 10:58 AM
Danny X
Ironhead
70
Jan 30, 2010 04:01 PM
snooper0069
Jul 1, 2007 09:47 PM
