10" Monkey bars....Stock cables work?
Old Sep 8, 2011 | 09:28 PM
redrubicon2004's Avatar
redrubicon2004
Default 10" Monkey bars....Stock cables work?
I'm going to be attempting to install 10" PYO Monkey bars on my 07 SG tomorrow. Will the stock cables (Clutch, brake, throttle, idle) work? How about the wiring?
I recall reading that rerouting everything will work, but would like to confirm this.
Thanks!
Old Sep 8, 2011 | 11:22 PM
rg_dave's Avatar
rg_dave
I think they'll work but a lot of guys go a little longer on the clutch cable so it doesn't bind. It will get pretty tight.
Old Sep 9, 2011 | 12:55 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
You will need +4" over stock for proper slack. You don't want to over stretch the stock cables.
Let us know if you need any help.
Thanks!
Shawn
Old Sep 9, 2011 | 05:21 AM
Fast FLHX's Avatar
Fast FLHX
A lot of people use the stock cables.
Old Sep 9, 2011 | 05:33 AM
Kesean's Avatar
Kesean
+1 on the cables
Old Sep 9, 2011 | 09:01 AM
Beemervet's Avatar
Beemervet
Stock cables work perfectly, reroute the clutch cable.
Old Sep 9, 2011 | 09:12 AM
Plasteredcat's Avatar
Plasteredcat
I ordered the cable kit from PY and only ended up using the Clutch Cable. Everything else wasnt needed. I hope you are a religious man cause those bars are a MPINTA to pull wire through. Yours will not be as bad as 2010+ Fly by wire plus control wires sucks to pull through those bars. BUT after its all said and done and you have taken what ever kools your nerves you will love the bars. Have a wonderful day!
Old Sep 9, 2011 | 09:36 AM
steelerdude1's Avatar
steelerdude1
Keep us posted on the install. I would love to know your results without changing the cables. I have always felt more comfortable with higher bars. Not extremely high, so I think the 10" would be perfect for me. In the past, when I changed out, the cables and brake hoses were a lot of the cost, and the brake lines/hoses were a PITA, more so getting them to bleed then the install.
Old Sep 9, 2011 | 10:18 AM
Fast FLHX's Avatar
Fast FLHX
I had this done with all stock lines.
Old Sep 9, 2011 | 10:06 PM
BackRoader's Avatar
BackRoader
If you re-route your clutch cable from behind and over the top of your radio to under it, you will gain about 3ish inches.
