security module
Old Sep 9, 2011 | 06:22 PM
hoggy05's Avatar
hoggy05
Default security module
where is the security module located on a 10 limited?
can a module from a 10 nonsecurity bike fhx, be used to make the limited a nonsecurity bike?
Old Sep 9, 2011 | 06:29 PM
lh4x4's Avatar
lh4x4
So you didn't get a service manual for your bike. It would answer many many questions.
Old Sep 9, 2011 | 06:35 PM
DSMHAWG's Avatar
DSMHAWG
The security module is under either the right or left side cover. Sorry have been away from the HD world for a little while. Can't remember which side it is. Yes you can use a non-security module for the bike. It will need to be pass word learned from the DT2 computer at a local dealer.
Old Sep 9, 2011 | 06:44 PM
ibridn's Avatar
ibridn
Stage II
Its under the left side cover. Just installed my alarm module with antenna for my pager on 11 Limited.
Old Sep 9, 2011 | 07:59 PM
Smittyjf's Avatar
Smittyjf
You can marry the TSSM to the ECM with these instructions:
1 Set Run switch to Run
2 Turn Ignition key On-Off-On-Off-On-Off-On and then toggle
the Left Turn Signal switch twice.
3 Turn Ignition key Off-On Verify the Check Engine lamp and Security Lamp illuminate
briefly and then turn off Security lamp will not illuminate on non-security
(TSM) Twin Cam models.
4 Attempt normal start one time. Engine starts and stalls immediately. check engine
lamp stays on. Password has not been learned and sets trouble code P1009, thus stopping fuel
flow.
5 Wait 10 seconds Security Lamp remains lit for V-Rod and TC88 with TSSM. Lamp will not be on for TC88 TSM models. ECM enters Password Learning mode for 10 minutes.
Do Not cycle the ignition or disrupt power.
6 Wait until Security Lamp turns off or a minimum of 10 minutes has passed.
7 Quickly (within 2 seconds) turn Ignition key OFF-ON Security Lamp remains lit for V-Rod and TC88 with TSSM. Lamp will not be on for TC88 TSM models.
8 Wait until Security Lamp turns off or a minimum of 10 minutes has passed. Password Learning mode for 10 minutes. Do Not cycle the
9 Quickly (within 2 seconds) turn Ignition key OFF-ON Security Lamp remains lit for V-Rod and TC88 with TSSM. Lamp will not be on for TC88 TSM models.
10 Wait until Security Lamp turns off or a minimum of 10 minutes has passed. Password Learning mode for 10 minutes. Do Not cycle the ignition or disrupt power.
11 Quickly (within 2 seconds) turn Ignition key OFF-ON Security Lamp light and then turn off. Lamp will not be on for TC88 TSM models.
12 Turn Ignition switch OFF. Wait 15 seconds. Turn Ignition switch ON and start engine to confirm the Password Learn Procedure is successful. Engine will start and remain running
If engine immediately stalls and fails to restart the Password Learning mode was not successful. Start over at step 1.
Old Sep 9, 2011 | 08:48 PM
geezer glide 56's Avatar
geezer glide 56
The TSSM is under the right side cover...The security siren is located under the left side cover.
Old Sep 9, 2011 | 08:49 PM
Potato_Potato's Avatar
Potato_Potato
The siren is under the left side cover, if you have one. The security module (TSSM) is under the seat on '08s anyway.
To check what year fits what year you can determine that by looking at HD website or the big book.
Old Sep 12, 2011 | 08:34 PM
Egras2k's Avatar
Egras2k
The module is under the seat, siren is under the left side cover on mine.
Old Sep 12, 2011 | 08:59 PM
dawg's Avatar
dawg
Yes, it's a matter of changing the 68924-07 SMART SECURITY SYSTEM MODULE to a 68920-07 TURN SIGNAL MODULE
Old Sep 12, 2011 | 10:49 PM
HighLiner's Avatar
HighLiner
Do you need to do the relearn procedure stated above if your going to the non-security TSM?
