Decel popping
Old Sep 17, 2011 | 08:24 AM
crazzy76's Avatar
crazzy76
Default Decel popping
My friend has a 2011 street guide.
He just put on a new stage 1 kit.
Rhineharts true dials, big sucker air breather, and thundermax auto tuner.
The Rhineharts sound great, but he gets so much popping when decelerating?
I thought the thundermax auto tunes everything.
He's really happy about the sound, but not the popping.
Does anyone have any suggestion?
Thanks!
Old Sep 17, 2011 | 08:46 AM
paguy's Avatar
paguy
Something I found out the hard way. Did you install new muffler clamps?
Old Sep 17, 2011 | 08:51 AM
BlueDragon's Avatar
BlueDragon
Assuming he first started with a good base map... the auto tune will only auto tune if it's 'turned on' properly... ie; "turn switch on for 20 seconds turn switch off for 20 seconds" so on and so forth. Anytime the battery is disconnected, main fuse pulled, or total loss of power, this ritual needs to be performed upon re-powering up for the auto tune to take affect on the T-Max.
bigdumbnoitall00's Avatar
bigdumbnoitall00
most liklley cause ,exhaust leak.
Old Sep 17, 2011 | 09:01 AM
lionsm13's Avatar
lionsm13
Dyno it if possible to get the correct map for it.
If not have him get with T-Max, since it's their product.
Old Sep 17, 2011 | 09:03 AM
Bearcat1's Avatar
Bearcat1
After I had installed my Rineharts I had bad decel popping. I was able to quiet it down some after finding and sealing a leak where the header pipe and muffle clamp together. But they still gurgle and pop little. Have come to accept it's just the nature of the beast because of the wide open nature of the Rinehart design.
Old Sep 17, 2011 | 09:44 AM
fabrik8r's Avatar
fabrik8r
Too rich, too lean, exhaust leak, and normal are the common answers, figuring out which one is correct is the trick. Personally I subscribe to the too rich and normal theories, once any exhaust leak is eliminated. You can't have a pop without fuel, air, and an ignition source, and you can't absolutely control fuel shut down on decel, always a little residual fuel from the on/off throttle transition. I don't care how rich you tune a bike in an attempt to cool it down, there will always be enough heat in the pipes to serve as an ignition source, so work the issue of removing air and fuel. I've tried all the tuning tricks recommended here and nothing so far completely eliminates it, I accept a little poping as normal, but thats just me. What I can say for sure is the richer I tuned, the more popping I got. Then again I'm just using a PCIII, one of those high end tuners may better mitigate the popping.
Old Sep 17, 2011 | 10:01 AM
SICKBAGGER's Avatar
SICKBAGGER
In most cases if it is not an exhaust leak the if your can richen the 0 throttle position it will go away. Not familiar with the Thundermax as I have PCV/AT good luck you will get it.
Old Sep 17, 2011 | 10:43 AM
voodoodrug's Avatar
voodoodrug
I resently had the same experience with bub true duels. retuned with the new feature the tts mastertune added which ajusts for cam base...ect didnt even use the data collection just the estamator function and all the popping is gone! like said before a leak in air,exhaust or retune.
Old Sep 18, 2011 | 06:49 PM
journeyman's Avatar
journeyman
Thanks!
As far as the Tmax goes, your friend should be running base map #113 for his set up, and be sure he initialized it properly.
Next check, go to Module configurations then select the Basics settings tab and look at the Decel Fuel Cut parameter, be sure it is set to 1
