You dont need to take the exhaust off if you use the method above!! but if you insist on doing so it is not to hard just time consuming!! I would not if i didnt need too!
You don't need to take the exhaust off if you use the method above!! But if you insist on doing so it's not to hard just time consuming!! I would not if I didnt need too!
The 2 Allen bolts that are loose are below the cover. Not the lower bolts of the 6 speed cover.
The 2 Allen bolts can best be accessed from the bottom side. I will have to shorten an Allen wrench in order to get into the Allen bolts because the exhaust is in the way.
Thanks for the input.
Yes those are the ones that hold the exhaust bracket correct?? if so i was able to get to them!! Good luck!!
http://www.phatperformanceparts.com/...p/kas-6529.htm
To install and remove rocker box covers
9 3/4" long chrome-plated single-end reversible wrench has a 1/4" drive and 3/16" replaceable Allen bit end Low profile to allow clearance between frame and engine
Comfortable, ergonomic rubber grip
Rubber will not scratch chrome or paint
Made in the U.S.A.
This is what I use and do all the HD Wrenches at my local.
The HD Dealer came out with a 1/4 inch drive wratchet with an allen head socket. He got in there with a glove and tightened them up in 20 seconds. No pipes coming off or nothing.
He torqued them to "MF tight" with one hand and that was it. I was there about 5 minutes.
I "thought" it was going to be a pipe project as well...I didnt even try to tighten them. When I saw how easy I was a little embarrassed.
Same bolts loosened on mine at about 5000 miles. Used the method above with the long shank of the Allen wrench. Tightened them back and they have been snug ever since. Some guys cut-off some of their Allen so they can actually get it in the head and torque it down good. When I replace the header, I will remove these bolts and replace them with a Grade 8 bolt with a lock washer and blue thread locker. They are not very visible at all. This is a very common problem, unfortunately.
