Supertrapp 4" Stout assembled incorrectly?
Looking at your pix (sweet bike BTW) I don't think I have my pipes installed correctly, I think I need to push them farther forward. I have maybe 2" I could go, forward, before I hit the heat shield. I was trying to make them stick out from under the saddlebags a little farther. Maybe I'll reconsider that. I did try to ensure that the clamp and the outer diameter of the slipon had ahold of maybe 1" to 1 1/2" of inside exhaust tube.
i have the 140-65224 and mine are about an inch back from the shield, you should push them all the way forward so they seal good, when i looked into my pipe i don't have nothing but a straight run threw. nothing hanging down and NO light coming thru, but you probably have a different pipe then me beings i have an 2010, but you shouldn't be able to see light like ya said. wait till they burn in a little they only sound better, love mine
If you look at the picture I uploaded with my original post, you can see that there's definitely light shining through there. But, as someone suggested, even with the left side being more open, when the motor burning I get more exhaust out the right side than I do the left. I even had the Wife hold the throttle open between 2 and 3k rpm and the left side never had the output that the right side did.
So anyway, i think i will push them forward closer to the heatshields, even them out left and right. And I'm looking forward to them sounding better as they 'season', they sound good now, I can just imagine how they'll sound once they get broken in.
Sometimes during production, cores will be assembled a little off from each other, it is cosmetic only, they function the same.
There is a difference between the cores on 2010+ mufflers vs. -2009
The later model cores were designed specifically for use on the stock/CAT equipped head pipe. They will work on the older non-CAT headpipes, but they will be substantially louder on those bikes.
But good info for people looking at ALL the options.
If you do have questions, you can post to our forum as well, however it is only monitored during working hours-Monday thru Friday-we do have to ride sometime!
Thanks,
Jeff
SuperTrapp Industries
I pushed both exhausts all the way in, then I took out the ruler and noticed the right side was farther in about an inch. So I pulled them back to were they both line up evenly from the saddlebag. I will check again with a level.
Anyways, these have a realy good deep sound. I wear a fullface and earplugs so the noise is just like the website has stated. A little louder than stock, but not obnoxiously loud. Open up the throttle and it gets a little louder.
Since it is getting colder, the heat isn't really an issue for me. The last performance mod I will do is just an aircleaner and pretty much be done
