HID on street glide
Old Sep 20, 2011 | 07:15 PM
jwwc17's Avatar
jwwc17
4th Gear
Default HID on street glide
I recently put in a HID bulb in my street glide but have a question before I try to use it. The installation says to make sure I use a 20amp fuse for the headlight, so does anyone know if the wiring can handle the 20amps? Also I just got this bike so can someone tell me where to find the fuse box/panel? Its a 2011
Old Sep 20, 2011 | 07:30 PM
Mntsnow's Avatar
Mntsnow
Fuse box is under the left sidepanel just in front of the saddlebag
Old Sep 20, 2011 | 08:01 PM
Moneywoes's Avatar
Moneywoes
A true HID bulb would need a ballast also, if its just a replacement bulb plugged into your factory headlamp plug it's not a HID bulb I don't think??
Old Sep 20, 2011 | 08:20 PM
Hoblick's Avatar
Hoblick
True. My hid is a balast and harness, im running a 55 watt kit, so it has an extra harness for power that comes from the battery and has a fuse in the harness. The power from the street glide harness is used essentially as a power on switch.
If using a 35 watt kit the power comes from the stock sg harness but a ballast is still used. And yes stock wiring is enough to handle a 35 watt hid.
Old Sep 21, 2011 | 07:08 AM
jwwc17's Avatar
jwwc17
4th Gear
It did have a ballast, but it still received it's power from the factory wiring. Thanks for the info
HYPR
Jun 17, 2015 03:44 AM
HYPR
Jul 30, 2013 05:54 PM
Big Johns Harley
Nov 9, 2008 06:44 AM
ko4qc
Jun 5, 2008 10:39 PM
Crazie
Mar 16, 2006 12:22 AM
