I am open to suggestions on what should be added / improved.
Since you already have the 'Where Am I?' feature, a 'Take Me Home' feature would be great, automatically routing you back home based on a previously-set home address and your location at 'Where Am I?'.
Looking at your alarm pin over ride instructions, you have step 11 and step 12 with each step pressing the right turn signal switch. In my 2007, after you enter the "e" digit, you only need to press the right turn signal one time. I'll try pressing the right turn signal twice after the "e" digit on my model and see if it still works. If that's the case, you may not need year specific instructions. Thanks again.
I believe the EITMS instructions only work for 2009 and later models. My 2007 needs a software download to the ECM to activate this feature. Thanks again.
I'm considering putting this as a sticky subject but since it really applies to all HDs with security, I think it belongs in General HD Chat and not just in Touring.
Comment if you like. I'll decide tomorrow.
Good idea. You can always un-sticky it if it fizzles out. I did not realize before how much people love their phones.
So would 2007 and 2008 touring model years be the same, with changes coming in 2009?
Late 2008 models also have the feature. I have an early 2008 (July 2007) and I gained the feature by enabling it with my TTS MasterTune. If you go with 2009 and later you will be correct but will be omitting late manufactured, and some modified, 2008's.
I also loaded a note pad App that can encrypt your notes. I have put my start code there and named the note after my bike's nickname. That is then encrypted and I need to enter a password in order to read it...
Good idea, I do the same with "Note Everything Pro" from the Android market.
