Battery has 12.76 volts. When running at battery 13.86volts. (with meter)
Volt gauge on fairing 13+ volts.
As soon as I turn on lights, signal or brake.
The volt gauge goes below 12volts (discharge)
Looking for ideas of what to look for?
I had the same problem. You have a short somewhere. I found mine at the neck in a bundle of wires. Look for wear on on the sheathing and you'll find the short. Year and make please.
my readings were showing the same thing, so i checked the battery connections and had the battery load tested, found it had 2 dead cells got it replaced, so far so good, just sayin before ya start looking else were.
I have a 1991 FLT and volt meter has read exactly 2 volts below voltage checked at battery since new. I believe it is correct that volt meter is wired (poor engineering, but maybe saved 5 cents on extra wire at factory) in line with other accessories (lights) which causes incorrect reading. When I hook voltage gauge direct to battery, the meter reading is correct. For the past 20 years, I have just added the missing two volts to the reading when checking voltage through the volt meter.
