Wind Deflector Issues
Old Oct 8, 2011 | 08:52 AM
SeniorChief56's Avatar
SeniorChief56
Veteran: Coast Guard
Default Wind Deflector Issues
2009 Road King Classic....I put them on a couple days ago and the first attempt they hit the back of the turn signals, so thinking I had them on the wrong side, I switched sides. Now I can not turn my bars full right or left without the deflectors hits the crash guard. Now what?
Old Oct 8, 2011 | 09:15 AM
Port Dawg's Avatar
Port Dawg
Same here...they barely do not touch the signals and I mean a sheet of paper barely...I just don't turn full left..right seems ok
Old Oct 8, 2011 | 09:42 AM
SeniorChief56
nevermind> I had them on backwards and I need to put the turn signals in the forward part of the peanut shaped hole. And what a PITA it was to move the turn signals forward. Removing the 2 allen screws in each lite was a PITA. Then I had to cut the single gray wire so I could remove the 1/2" nut. Soldered and heat shrunk the splice, reattached everything and it does not hit the crash bar or back of the turn signals. Almost a 2 hour job.
Old Oct 8, 2011 | 11:54 AM
SeniorChief56
was I the only one that had to cut wires?
Old Oct 8, 2011 | 01:47 PM
uscanuck's Avatar
uscanuck
There is some adjustment possible when mounting these plus your lowers may not be installed exactly the same.
I just put the deflectors in my vise and bent them slightly outwards which gave me plenty of room when installed.
Old Oct 8, 2011 | 01:49 PM
Dale_K's Avatar
Dale_K
I didn't even know there was a peanut shaped hole. If I set mine up to miss the turn signal they touch the crash bar at full lock. I was going to post a thread asking about moving the turn signals but maybe somebody will respond to yours. Somehow I doubt you need to cut a wire but I'm the same guy who put the defectors on backwards twice already.
Old Oct 8, 2011 | 01:55 PM
shortride's Avatar
shortride
When I had my Road King Classic I just bent the wind deflectors back a little to clear the turn signals. There ended up being about 1/4" clearance.
Old Oct 8, 2011 | 03:20 PM
Sailrider 1's Avatar
Sailrider 1
Mine barely touch at full left lock..I left them alone, how often do I turn full left lock ?
Old Oct 8, 2011 | 03:35 PM
MNPGRider's Avatar
MNPGRider
Yep ! Take an old, cheap socket, and cut a 1/16th notch down the side with a Dremel tool to slide the wire into. Turn the nut a quarter turn at a time, and reposition the socket.
Harley actually sells a socket made just for this job.
The deflectors can also be adjusted by bending them slightly. I run them on my Ultra with lowers with about 1/4" clearance behind the signals and in front of the lowers.
Attached Thumbnails Wind Deflector Issues-turn-signal-clearance.jpg   Wind Deflector Issues-winddeflector-001.jpg
Old Oct 8, 2011 | 04:22 PM
Tortoise98's Avatar
Tortoise98
Just remember, if it was easy anyone could do it! Just think about that overwhelming sense of pride you are now feeling because you tackled a difficult task! This is called living life to the fullest...
