Quick release back rest
Old Oct 8, 2011 | 05:40 PM
7Sixpack7's Avatar
7Sixpack7
The front pair are wider to accommodate BOTH the sissy bar AND the rack. The rack uses all 4 points of the docking hardware and the sissy bar only the front 2 and the shock mounts.
Edit to remove quote after re-reading it.
Old Oct 8, 2011 | 05:53 PM
frog13's Avatar
frog13
Originally Posted by drukanfu
Put it (the backrest) in a vice and bend the frame just a little at a time till it fits properly.
Mine was off about an 1/8"-1/4" (yeah, yeah, 5/16") adn I thought maybe I had something wrong, so I read the instructions that came with the sissy bar upright. It says something to the effect that minor adjusting may be needed. I just kept adjusting until it slips right on and off.
Old Oct 8, 2011 | 05:54 PM
7Sixpack7's Avatar
7Sixpack7
Originally Posted by mtclassic
yes percisely, there is only one set of docking points that can be used with the sissy bar.
You are correct! I misread your post.
Old Oct 8, 2011 | 05:58 PM
mtclassic's Avatar
mtclassic
Originally Posted by 7Sixpack7
Nope.... The front pair are wider to accommodate BOTH the sissy bar AND the rack. The rack uses all 4 points of the docking hardware and the sissy bar only the front 2 and the shock mounts.
Old Oct 8, 2011 | 06:33 PM
Vile Lou's Avatar
Vile Lou
I'll bend it out I guess. And yes, I'm using the shock posts for the front. But the back isn't spread out wide enough to latch on. I thought I had installed the 4 point incorrectly but I guess it just needs some massaging.
Old Oct 8, 2011 | 06:39 PM
blueduramax's Avatar
blueduramax
When you put on the docking hardware did you remove one bolt from the bike? I know I tried to put my mounting hardware on leaving that bolt it place and it did not work right. It doesn't seem right that you have to bend anything.
Old Oct 8, 2011 | 06:42 PM
Vile Lou's Avatar
Vile Lou
I did remove the bolt yes. They line up nicely on both sides. But the sissy bar isn't wide enough on the back side to clip in.
Old Oct 8, 2011 | 07:16 PM
caspr2's Avatar
caspr2
Once you get it on leave it on the bike for a month or so. After that it will be easier to install.
Old Oct 8, 2011 | 09:26 PM
mannya4's Avatar
mannya4
Didn't have a problem with mine on my 2010 FLHX. Guess i just got lucky with a good fit!
Old Oct 10, 2011 | 09:24 AM
Vile Lou's Avatar
Vile Lou
Played a little tug of war with a friend using the sissy bar. Now it's mounted and is nice and snug. I read a couple of posts from guys complaining about rattling and there's none if that. Thanks guys.
