more torque values needed please
Old Oct 8, 2011 | 02:38 PM
vduzin12's Avatar
vduzin12
Default more torque values needed please
The upper fork pinch bolts on the lower tree. any loctite? there was none on the bolt when i removed it. Also the four bolts that hole the ignition cover on. torque specs and color loctite. Lastly the four bolts that hold the inner fairing to the frame. I have a manual on order and will not be in until tuesday. Its a 2012 fltrx. thanks again
Old Oct 8, 2011 | 04:05 PM
tj316's Avatar
tj316
pinch bolts , 53-57 ft lbs / ignition switch housing nut 85-115 in lbds ,screws 30-60 ft lbs (not sure which you want) /inner fairing to frame 20-30 ft lbs
kdfoster
Sep 13, 2011 06:02 PM
ski3ski
Sep 20, 2010 12:39 PM
HOG_0308
Jul 18, 2010 11:01 PM
neocontra
Oct 6, 2009 04:16 PM
jokerx
Feb 8, 2009 06:29 PM
