Tire pressures
Bike and car makers recommend a tire pressure based upon the characteristics of that particular machine. To deviate more than a tiny bit from that recommendation can cause handling issues, at all the wrong times.
Vehicle Manufacturers recommendations are a compromise of many factors, i.e., ride comfort, fuel mileage, wear characteristics, handling characteristics, etc., and are recommended to provide satisfactory performance under typical and varying conditions for a wide range of users.
Varying tire pressures can actually improve performance and safety for different riders under different conditions.
For the average rider under typical conditions, I see absolutely no issue with my original recommendation of running the tire pressure anywhere between the vehicle manufacturers recommendation and the tire manufacturers maximum rating.
For the sake of argument, and I'm be no means recommending this, you could probably run a tire above the maximum rated pressure without issue because the max pressure rating is engineered with some safety factor designed into it.
