2006 electraglide turn signal issue
Old Oct 12, 2011 | 08:41 AM
rider's Avatar
rider
Question 2006 electraglide turn signal issue
right rear turn signal only comes on and dash indicator and stays on, sometimes by itself and sometimes when hitting a bump, will also go off by itself or after a bump! Wiring and conections have been checked from under seat to tailight,and circut board in tailight housing has been replaced!! All grounds have been removed and cleaned and secured! Any help would be appreciated! THX
Old Oct 12, 2011 | 08:56 AM
jackhis's Avatar
jackhis
It appears like there is either a loose, or a short connection somewhere.
I would check the switch first.
Old Oct 12, 2011 | 09:00 AM
Uncle Larry's Avatar
Uncle Larry
Try replacing the turn signal flasher before you get too deep. Just my .02 cents worth.
Old Oct 12, 2011 | 09:24 AM
vzts4q's Avatar
vzts4q
There is no turn signal flasher on any recent Harleys! All the turn and hazard functions are controlled by the TSM ot the TSSM if you have security. And this is not an easy or cheap throw a part at it fix.
Old Oct 13, 2011 | 12:16 PM
Uncle Larry
Yep --- you're right! I guess I'm showing my age.
Old Oct 13, 2011 | 01:43 PM
ses's Avatar
ses
Are you positive the wiring harness under the rear fender is good? Had the same issues and found that my rear wheel had rubbed through the harness under the fender.
jstrebe
Electrical/Lighting/Alarm
Aug 14, 2014 08:45 PM
bstofferahn
Apr 19, 2011 12:29 PM
rdbateman
Sep 15, 2010 11:37 AM
MOSTWANTED
May 22, 2009 03:23 PM
Tx883c
Nov 14, 2005 01:41 AM
