Starter
Old Oct 15, 2011 | 03:56 PM
Roadglide2006's Avatar
Roadglide2006
Stage III
Default Starter
I have a 2006 Roadglide with a 103 Screamin Eagle upgrade,I need to put in a new starter and I am looking to put in a 2.0K. Can anyone suggest a good brand and best place to get it.
Old Oct 15, 2011 | 04:04 PM
Stiggy's Avatar
Stiggy
103 in a 2006? Do you have 4" cylinders?
The problem with the High Torque starters, ( that were really popular back in the 90's,) is that though they give you additional windings for more power, they transmit that power through the same gear reduction and starter drive clutches as the stock starter, and that's where the failures occur.
I'd run a stock starter with compression releases if the stock unit won't do it as is.
Old Oct 16, 2011 | 06:56 AM
Roadglide2006
Stage III
Default Starter
I have compression releases and have had the starter replaced and I still got a grinding noise when starting. Now it won't start just whines.I've brought it to HD Dealers,Indys,and now I'm looking to buy the parts and fix it myself.I've installed 4AWG copper battery cables,new battery,starter and even bypassed starter switch and nothing seems to stop this.I'm tired of being the guy in a ride that makes everyones head turn when I start my bike.
Old Oct 16, 2011 | 09:18 AM
Stiggy's Avatar
Stiggy
The whining is probably a starter drive clutch, ( one of those 'stock' things that wear out first, and is the same on all starters, stock or High Torque.) It's a $60 unit aftermarket.
There's no warranty on the starter you just had replaced?
magnum629c
Nov 18, 2018 04:54 PM
98hotrodfatboy
EVO
May 11, 2017 08:27 PM
BocaBob
Apr 14, 2016 10:01 AM
dogbone
Oct 6, 2011 10:14 AM
Bluesrider
Jan 6, 2010 11:32 AM
