rear agitator effect on speedometer
Old Nov 3, 2011 | 10:41 PM
Cowboy Rob's Avatar
Cowboy Rob
Big Kahuna HDF Member
Originally Posted by skratch
which way? is the speedo reading faster or slower than you are actually moving? if faster, i would ignore it and act as if it is accurate. we can all use a little 'cushion' from time to time.....
Yeah it reads faster,and I kind of like it. The extra cushion is nice,especially in the Commonwealth of Virginia,lol.
Old Feb 23, 2021 | 11:55 AM
twincam10353's Avatar
twincam10353
Sorry to dig this coffin out of the cemetery - going from a 16" to an 18" rear wheel, where is the height increase actually noticed? Is it the measurement from the ground to the center of the axle?
Old Feb 24, 2021 | 07:30 AM
roussfam's Avatar
roussfam
An 18" rim will be 1" taller from the axle to the lip of the rim. Normally a lower profile tire will compensate for the larger rim BUT lower profile tire usually translates to a harsher ride. A 16" rim will give you a smoother ride with the taller profile. If you go to an 18" rim and use a higher profile tire it could rub on the underside of the fender or hit when going over bumps.
So smaller rim with taller tire equals smoother ride. Looks or function it's your choice.
Jim
Old Feb 24, 2021 | 09:23 AM
skratch's Avatar
skratch
the difference between the stock 16'' wheel/tire and the stock 18'' wheel/tire is a total of .6''. so from ground to center of axle, .3''. even with my short legs, i find that pretty negligible.
Old Feb 24, 2021 | 10:35 AM
roussfam's Avatar
roussfam
Yup. Difference of 16" with higher profile tire and 18" with lower profile tire is not that much. Some people find the ride harsher but like the handling better. Same deal with cars.
Old Feb 24, 2021 | 01:15 PM
skratch's Avatar
skratch
i really don't notice it that much. but then, i've been running the 19/16 combo since 2010 or so when i put chrome agitators on my bike. i like the look of the larger wheels and have just gotten used to the 'firmness' of the ride. but i did upgrade the stock suspension too so that may have something to do with it as well.
Old Feb 24, 2021 | 08:49 PM
kblhd's Avatar
kblhd
18 inch on my Street Glide couple of mph off not a big deal I guess unless your in a school zone.
Old Feb 25, 2021 | 05:50 AM
jake24lt's Avatar
jake24lt
easily adjusted if you own a power vision.
Old Feb 25, 2021 | 08:21 AM
twincam10353
If a 16" rear offers a better ride, why did HD switch to 18" rears on the touring models?
Old Feb 25, 2021 | 08:35 AM
roussfam's Avatar
roussfam
Why do people put 21" on the front? Different look, different style
