Does the PCV compensate for cold temps?
Old Oct 25, 2011 | 10:49 AM
Keithhu's Avatar
Keithhu
Originally Posted by hopperop
When it gets cold, fuel mileage goes down
Fuel mileage will go down a bit in colder weather.
"hot air is less dense than cold air; therefore, the engine breathes less hot air per revolution and requires less fuel"
http://www.swri.org/10light/mile.htm
Old Oct 25, 2011 | 10:50 AM
Harleydaddy's Avatar
Harleydaddy
This may sound dumb, but what the hell is a PCV (PC-V)and why do I need one?
Old Oct 25, 2011 | 11:03 AM
dohadex's Avatar
dohadex
Red face ??
Power Commander 5...known as a PCV, PC-V, etc. It's a programmable Electronic Fuel Injection Module.
Old Oct 25, 2011 | 11:08 AM
Harleydaddy
Thanks dohadex. I feel more intelligent already!
Old Oct 25, 2011 | 11:21 AM
Lonewolf176's Avatar
Lonewolf176
deleted
Last edited by Lonewolf176; Oct 25, 2011 at 02:06 PM. Reason: thought it was cold star/warmup issue
Old Oct 25, 2011 | 11:28 AM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
You should have no problems with your PC-V map based on weather conditions. The HD/Delphi ECM is a speed density system which is based off of absolute pressure, as conditions change the system uses incoming air temperature vs MAP (manifold absolute pressure) to determine air mass which is then used to determine fuel delivery requirements. This happens many times per second, and in most cases very accurately.
As noted earlier you will use more fuel in colder temps as the air itself is more dense requiring more fuel to maintain the correct air fuel mixture.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Oct 25, 2011 | 11:37 AM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
It's getting colder and I noticed that my bike seems to stay in "open loop" mode longer as it warms up.
My questions is this: Do I need to re-map for colder tempretures? Maybe a richer overall map?
What you are seeing is actually "cold enrichment" which is based on temperature. In colder weather the system will maintain a richer mixture much longer than in warmer temps
Old Oct 25, 2011 | 01:17 PM
dohadex's Avatar
dohadex
Wink Thank you...
Thanks Jaime.
I can certainly trust your response.
Old Oct 25, 2011 | 01:48 PM
hopperop's Avatar
hopperop
Originally Posted by frog13
You should consult a good tuner ....... you definitely have a problem. That is why these bikes are fuel injected and have an ECM, to accomodate for different fuel mixtures under different conditions. That is the whole purpose of a tuner, to give you the optimal mix of air and fuel under the prevailing conditions. Before this, a carbureted bike going from low altitude to high would need to be adjusted to accomodate for the loss of oxygen, today's bikes do this automatically. The same for temperature, you seriously should not have to change your map for the seasons. Holy crap, where I live, it was in the 80's one day, the 40's the next, I would have to flash my ECM every morning based on the weatherman. Sometimes there's a 40 degree swing between mid day and mid night.
I have been to a good tuner, one of the best and well known in the country. The bike runs very good. When it gets cold the mpg goes down no matter what. Seems to me it runs a little rougher too, I'm not saying it runs bad, but I can feel a difference. Maybe that's just how an engine feels when it is sucking cold air and using more gas, I don't know. But when it drops to a high in the 40s I make it a little richer, not much, you wouldn’t notice a fuel drop because of it, maybe all it does is make it a hair more responsive but it makes me feel better. But about the lower mpg in cold weather, that is just how it is. As long as the roads are fairly clear I'm on my bike fall and spring when there is snow everywhere. The mpg difference between those cold months and the warm months is very noticeable.
Old Oct 25, 2011 | 02:35 PM
frog13's Avatar
frog13
I guess it was a misinterpretation of "rough", if my bike was running "rough" I would worry. I don't really notice any difference to describe as "rough" so we may not be thinking the same thing. But, to me, what you are saying is counterintuitive. Yes, you use more fuel in colder weather to compensate for the denser air, so your MPG could go down because your tuner compensates for the air. Making it richer is just going to add yet more fuel, making your MPG go down even more. But, if it makes it feel more responsive to you, excellent, but that woud be an indication to me your map is off because it should have made the correct compensation for you. Just my $.02 ......
