95" Motor???
I have a 2003 EC Standard. It is also carbed. I have a SE air cleaner along with ing. mod. I am also running true duals. I am considering a 95" harley BB. Along with cams and head work. Maybe SE heads with some additional porting work. I mostly tour and about 30% two up. Just looking for some feed back or suggestions before I drop any coin. Thanks
Only feedback can give you is the fact that the 95" upgrade is/was the best coin I've spent on My '99 Ultra. Hands friggin down. I ride two up only 25% of the time. It's a 50% improvement over the stock 88" TC. Have the screaming eagle breather along with the Power Commander,and the ThunderHeader slip on's.
Outlaw
Outlaw
I thought I read on another post that the SE heads are more for the high rpm numbers, which you don't really use, especially 2 up. On that same post I remember them saying that it'd just be better to port your current heads. Plus when I look at the numbers on the dyno page it seems like most of the 100/100 numbers have stock heads that are ported and have new valves/springs.
Of course I could be wrong and I'm sure people that went through this can confirm/deny my memory.
ORIGINAL: Bryan TTM
call BigBoyz or RevPerf or GMRPerformance...buy a proven combo..you can do lots with ported stock heads for the riding you describe
Port you current heads, dont waste your $$$ on SE heads. Had them on my 03 Ultra with the 95" kit and 203 cams. After a SERT tune it was one peppy bagger!! Ran great great power 2 up.
ORIGINAL: Maddogs700srx
I went with more of a 'hot rod' setup and it took a lot of tuning to get it to not ping; and even now I need to run 92 or better octane or use booster. I've seen many set ups like I describe, getting 95% of my results with a much more 'user friendly' build.
I do not ride 2 up very much, but that is the biggest reason I did a 95" upgrade. The bike is a blast when I am solo, and has more than ample power when the OL is along for the ride. The bike is just so much more rideable now. I got a great deal on mine, but it would have been worth twice the price!
nogood o~`o
nogood o~`o
XfasteddieX
Exhaust System Topics
Sep 18, 2006 12:35 AM
