2002 to modern
Old Nov 1, 2011 | 08:01 PM
Kerls St.Glide's Avatar
Kerls St.Glide
Default 2002 to modern
How much money and work does it cost to change a 2002 road king to except a 2010 and up streetglide front and rear wheel?
I understand axle is different
will a 2007 SG set of wheels work
I love the rims and wanna do this as cost effective as I can
please input needed
or is there a kit someone sells
k
Old Nov 1, 2011 | 08:52 PM
coolerman69's Avatar
coolerman69
Front wheel is easy, just buy the 2010 axel. The fork lowers are the same. Rear im sure will bolt right on. Have a friend that did this and i dont recall him saying anything about having any trouble on the back.
Old Nov 1, 2011 | 10:53 PM
Texas Fat Boy's Avatar
Texas Fat Boy
No way will a 2009 and up rear wheel fit any bike 2008 and older.
Old Nov 1, 2011 | 11:02 PM
Eric The Welder's Avatar
Eric The Welder
for the rear wheel just get a 2006-08 16" rear wheel, it will bolt right in, for the front you can either get the 06-08 16" front SG wheel and its a direct swap, or go with a 17 or 18" from 09-11, all you need is the axle (66.00 at dealer) and the wheel spacers for the new 25mm axle.
you cant use a 08 or newer rear becasue they made them much wider in 09, it wont even fit in the swingarm.
Old Nov 2, 2011 | 07:25 AM
coolerman69
Kerl, fat boy and eric are right! I had forgotten how wide the rear is starting in 09. He must have used one from pre 08. The front was off an '11'. The 07 set you've found will work fine.
Old Nov 2, 2011 | 10:26 AM
02Ultra EG's Avatar
02Ultra EG
Put frt & rear '07 wheels on my '02 ultra with no problems.
JoesFLHX
Nov 9, 2022 10:51 AM
itsmf
Jun 16, 2012 04:10 PM
cburlette
Sep 24, 2010 02:59 PM
VintageBiker
Apr 25, 2010 09:53 PM
jabradley
Mar 7, 2010 10:39 PM
