Tightening the primary drain plug
There ya go; the right repsonse. I don't check the height but no leaks with the sealant.
To the OP and anyone else looking for information on this forum. I agree that this is a great place to obtain information but you can't just take what you read here as gospel. You have to be smart enough to sort through a lot of misinformation to get to the information you're looking for.
This thread is a perfect example. Of 10 replies that give a specific recommendation or answer to the original question:
Only 2 are the correct response as stated in the manual;
2 replies give a general instruction for NPT plugs and will work, but are not as stated in the manual;
And 6 replies are completely wrong (or do not apply) for the bike in question.
You can see that there is more misinformation than good information. And this is on an issue as elementary as a drain plug installation. Imagine the range of information you'd get on a really complex issue.
Be careful! It's up to you to sort through it all.
'03 Service Manual states the exact same thing. This is the right way to do it. The service guy at the local H-D said the same thing, just replace the O-ring ... but there ISN"T one, it is a NPT fitting.
Totally agree on the comment about information posted on this or any other forum; good advice. However, if you are saying that the manual way is the only way, we part company. The manual was written for shop techs, not DIY guys and, IMHO, there are alternatives to the manual means and methods that are just as effective.
I was simply using the "per manual" procedures as a point of reference in the context of my original post. I didn't mean to imply that it is the only way. In fact, one of the two posts I described as "will work but not necessarily per the manual" was actually mine.
I'm with you on there being more than one way to skin a cat.
But DIYs are also privy to the manual - It's not only for shop guys.
Why you should always buy a manual for your model and follow it to a tee. There are always more than one way to skin a cat but I would always follow the manual. At my dealership today asking about best way to torque the back left rocker bolt and the mechanics practically laughed at me. The rarely use torque wrenches. They know their stuff and experience is the key. I prefer exact manual instructions. Always refer to your manual and you won't go wrong.
Just serviced mine again today, '99RKC.
Manual doesn't give a torque spec. Looks as if the plug could be threaded all the way through the primary cover. Nylon pipe thread, inserted till plug was flush...no leaks. There's no o-ring either!!!
It's been stated before, ya get lots of information on this forum. Not all of it is true.
djl is spot on. I've got the manual and I follow it, but the bike isn't gonna fall apart if I deviate on non critical items.
Like was said earlier...
You can get all kinds of advice on anything up to / including engine builds.
Most dudes on this forum have never been inside their (or any) engine, doesn't keep 'em from posting advice...
vtwinhd59
04-10-2013 07:11 AM
