Different types of Metzeler ME880 tires?
Old Nov 8, 2011 | 05:50 PM
Stiggy's Avatar
Stiggy
There is a difference. I ran Metzelers until last year and have since gone to the E3 Dunlop. I had noticed back then that some retailers were listing some Metzeler tires models as 'OEM spec', in this case slightly stiffer sidewalls rather than the 'standard' tire we were all used to.
If it's an 'Alpha' number: MU or MT, it is a different tire than a '130' or '140'
Alpha being the heavier rated tire.
Eastern Performance Cycles sells both and have a short descriptions explaining further.
Old Nov 8, 2011 | 05:58 PM
drspencer's Avatar
drspencer
I want to get Metzelers for my 2007 FXSTC.
I need MH90-21 for the front and 200/55/17 for the rear.
If I'm not mistaken, the front is bias ply, while the rear is a radial.
Is it O.K. to mix & match like this?
Thanks
Old Nov 8, 2011 | 10:27 PM
thepun1sher's Avatar
thepun1sher
Avons are better, they have a better feel on the road and at crusin speeds
Old Nov 9, 2011 | 01:07 AM
Sol's Avatar
Sol
Originally Posted by SportyPig
I'm not sure where that came from about the Brazilian tires. Maybe it was a problem in the very early days of the Brazil facility. I've had German and Brazil tires...no difference in safety, performance or tire life.
I know what you're talking about...I've heard all the stories...But, from my first hand experience, I haven't noticed it.
To the OP...if you go with the Metz..check with them for the air pressure. In general Metz tires require a bit more air pressure.
I ride on Metzelers and recommend them to other riders.
The issue from a few years ago with the Brazilian-made Metzelers was that the tread would come off in chunks toward the end of the tire's lifespan (1st hand experience). Any tires from that period are now suffering from dry rot as well.
I forget if there was a recall, but Metzeler was straightforward about posting information on the affected tires and has since improved the Brazilian plant manufacturing quality.
Old Nov 9, 2011 | 02:25 PM
river rat's Avatar
river rat
good to know, I guess I won't worry about it then when I go to order tires in the spring
Old Nov 17, 2011 | 10:27 PM
MikeMihelich's Avatar
MikeMihelich
Metzler is a bad choice for a bagger. They can't handle the weight. I have seen more than one including my own bike (2007 Ultra) where the rear tire bulges or spits out large chunks of tread way before the tire is down to the wear bars. People say this failure is due to not enough air but I can tell you from personal experience that these tires fail even when running 44psi.
Old Nov 18, 2011 | 01:29 PM
Beemervet's Avatar
Beemervet
You may have had the early Brazilian tire. I've run nothing but Metz for over 100,000 miles, and they are are a GREAT tire for baggers.
Old Nov 19, 2011 | 04:32 PM
MJ's Avatar
MJ
You have to be careful which Metz tires you buy. Check the higher load rating. I got a rear one time that when it went flat, it was like a bicycle tire. Then the next one had a much stiffer side wall when it went flat. I bought a Avon one time and did not care for it all. I buy nothing but Metz.
hockey8787
May 23, 2011 07:28 AM
tut60
Wheels/Tires
Jun 25, 2009 10:21 AM
trafficjams
The General Motorcycle Forum
87
Jun 21, 2009 12:32 AM
DeuceRyder
Mar 12, 2008 11:05 PM
michaelschorpp
May 10, 2007 12:55 PM
